Old 01-24-2008, 09:41 PM
FSlodysko FSlodysko is offline
Default Getting stuck in Import Audio window
I go to import audio, select my audio, make sure it's in the Convert Region section or whatever it's called .. everything is fine. Then I go to click on "Open" and absolutely nothing happens. I then try to drag and drop the files into the region list and the program shuts down.
Any suggestions?
Old 01-24-2008, 11:36 PM
sky88dd sky88dd is offline
Default Re: Getting stuck in Import Audio window
Is the name of the file you are trying to import in English?
I once tried to import a file that was in another language and it did the same thing.
It worked after I renamed the file.
Don't know if it works for you but hope it helps.
PPC G5 Dual 2.0, 8.5G Ram
PT 8 cs2 OSX 10.5.8
MBP Core 2 Duo 2.16, 2G Ram
PT 8 cs2 OSX 10.5.8
Mbox 2 Pro, Mini, Micro
Import Audio Window Bug in 905 Zooce macOS 1 09-23-2011 01:08 AM
import audio window stuck! eranf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-27-2011 03:12 PM
Feature request - audio fader mods in Import Audio window digidesigner Pro Tools TDM Systems (Mac) 0 04-22-2009 12:14 PM
Import Audio search window results will not import BA Studios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-25-2008 09:00 AM
import audio from other movie -im stuck! Tom D. Digidesign Hardware & Software 1 03-11-2003 06:06 PM
