Old 10-27-2020, 01:18 PM
easyrider easyrider is offline
Default Pro Tools 2020.9.1 and Faderport 16 not working
I followed this from the manual
Is there something I am missing?
Tech:Audient ID22 and ASP880 / Yamaha MT120S / I7 /Win 10 Pro 64-bit /Pro Tools 2018 / Shure DMK57-52 /Rode NT1/ Oktava MK-012
Mic Pre's Focusrite ISA One/ DAV Electronics BG1/ Joe Meek VC3
Guitars and Instrumentation:Gibson Les Paul Zebrawood/Fender USA Telecaster/Fender Deluxe Strat/ Martin OM-18V/
Martin D15-M/Gibson SG Bass/ 1972 fender Musicmaster Bass/ 1972 Hayman Drums /Vox,Fender Amps/Roland F130R
Old 10-27-2020, 03:26 PM
Bob L's Avatar
Bob L Bob L is offline
Default Re: Pro Tools 2020.9.1 and Faderport 16 not working
Shooting in the dark, but I think it may be that you should unassign the FP16 as a MIDI Input Device.
My C|8 requires only the Peripherals Dialogue to be entered, but again it's a C|8, not a C|16.
Bob
Without a song
The day would never end
Old 10-28-2020, 04:57 AM
Did you set the Faderport to HUI mode and reboot it?
Also have you turned off the USB port power savings measures in Windows?
Is the Faderport plugged in and turned on when starting your computer?
Old 10-28-2020, 06:57 AM
You mean just uncheck it in that first pic?
Old 10-28-2020, 07:00 AM
Yep,
Hold first two select buttons , Power on FP16, select HUI, select exit. Reboot FP16
Launch Protools
Error.
FP16 plugged in and turned on when I boot, yep.
Disabled power settings in USB yep, Always do that...
Old 10-28-2020, 03:53 PM
Bob L's Avatar
Yup, that's what I mean. Again, shooting in the dark.
Bob
Without a song
Old 09-16-2021, 06:16 PM
gub gub is offline
I'm not sure if this has been covered?
However, I can't make a receive (send is fine) connection in Protools with my Faderport 16,
In the midi controller tab of Protools, PreSonsFP16,Prt1 andPrt2 show up in the Send to section, but they don't appear in the Receive drop-down menu.
So the faders work on the fader port when I use the faders in Protools, but not the other way around......
I've updated the firmware and I'm using a Mac mini..... and running the Universal control app.
Could there be a problem with the Audio Midi setup side of my Mac?
Any ideas?
Thanks
Old 09-19-2021, 02:14 PM
If you bought the FP16 new, the dealer would be my first point of contact. Second would be Presonus as they may have tech support available by phone. At this point, everything you do will be an experiment and I would start in that MIDI window at the top of your pics and uncheck everything for the FP and test. If that doesn't work, then add back each item, one at a time. From my own experience with HUI controllers, I have never needed to open that particular window for successful HUI function(still using my first-gen Faderport here)
anyone using a faderport with 2020? zwolf Pro Tools 2020 15 08-14-2020 01:32 PM
Pro Tools 2020.5/2020.3 Compatibility with Catalina 10.15.4? derrickhou macOS 4 07-26-2020 07:46 AM
Pro Tools (2020.3) on MacBook Air 2020 compatibility pellekuipers Pro Tools 2020 1 04-04-2020 08:01 AM
Presonus Faderport not working properly with v12.8 electrodaddy Pro Tools 12 10 08-10-2017 06:33 PM
Faderport not working correctly. WorldOfNoise Pro Tools 12 2 10-16-2016 07:43 AM
