Old 12-10-2003, 06:32 PM
tomcat tomcat is offline
Default how can i import 192 file into a 48 session?
Before you say "what a stupid question", check this out. I don't want to sample rate convert it. I want it to play abck at 1/4 speed. I can't seem to find a way to do this. PT 6.2.2. Inn the old days, when a file was imported, if it had a different SR than the session, it would warn you that it would play back at a different speed. Well, now, it just converts it.
I have heard that great ultra smooth speed manipulation can me accomplished this way for sound design. People have recorded insect flying at 192 and played the recording back at 48 and reported hearing all kinds of stuff that was previously above the range of human hearing.
Someone, please, say this is possible with my PT HD2, 6.2.2 on Panther with a 192 I/O. Thanks
tom
www.tompaul.com
Old 12-10-2003, 06:43 PM
RobMacki RobMacki is offline
Default Re: how can i import 192 file into a 48 session?
Very interesting.
Do you have Sinc I/O?
Can you tell Sinc you are @ 192 and PT @ 48?
Then play back @ 48?
I know I'v done this (by mistake 48 & 44.1) w/ USD.
Old 12-10-2003, 07:03 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Have you tried fooling Protools by changing the sample rate header of the file??
Use Soundhack to call it 49K
IMDB
Old 12-10-2003, 08:27 PM
yes, that is what i was thinking. a way to alter the resource fork, or whatever it is called, to make pt think it is a 48 k file. I don't know sound hack. any details appreciated!
tom
www.tompaul.com
Old 12-11-2003, 08:17 AM
Mark Reis Mark Reis is offline
SoundHack Freeware
It's simple enough to use. Open the file in question in SoundHack. Select HACK>Header Change (command H) from the menu. A dialog box will pop up indicating the current sample rate, # of channels and bit depth. Type in 48000 where it says 192000 and apply. The next time anything looks at the file, it will appear to have a 48k sample rate.
Mark Reis
Sound Designer
Old 12-11-2003, 12:20 PM
A 192kHz file won't have a resource fork.. you need something akin to my Header Investigator which runs under OS X -- you're dealing with either AIFF or WAV files here which don't have resource forks.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
"Import Session Data" Audio File Duplicates acstctws Pro Tools 10 1 03-01-2013 03:06 PM
Import Session Data with out Audio import disinfor Pro Tools M-Powered (Mac) 7 11-14-2010 11:44 AM
Import track color in import session data deardaddy Pro Tools TDM Systems (Mac) 5 06-11-2007 06:35 PM
can't import video file into the session.... EminTR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-24-2007 09:24 AM
Strange issue recurring file error session import AUDIOSFX Pro Tools TDM Systems (Mac) 0 10-12-2005 10:39 PM
