Old 05-11-2021, 07:59 PM
tbone63 tbone63 is offline
Default Added 2nd HDX card; RX580 video card fan rubbing against it! Yikes!
Hi, folks, just wondering if anyone else has experienced this and found a workaround. MacPro 5,1 tower, just added a second HDX card into PCIe slot 2, and slot 3 has another HDX card. (PCIe slot 4 has SSD drives in an OWC Accelsior SSD bay.) Now the fans in the RX580 rub against the HDX card.
Presently I’ve put plastic spacers in between the top of RX580 GPU and bottom of the HDX card, but it’s a tight jam and I don’t want to damage anything. Any suggestions?
Is there a way to house a PCI card or video card outside of the computer’s case? Thanks for any advice, cheers to all.
Old 05-12-2021, 07:28 AM
arche3's Avatar
arche3 arche3 is online now
Default Re: Added 2nd HDX card; RX580 video card fan rubbing against it! Yikes!
Only good solution is to use a magma pcie chassis for the hdx cards. Which is what i did for my 5.1. But I have used a little adhesive rubber spacer as well between the gpu and the card next to it. In the past it was a red rocket x card. As long as you don't move your rig it works.
Sent from my SM-G986U using Tapatalk
Old 05-14-2021, 01:34 PM
Hugh-H Hugh-H is offline
Hello,
All ours are that way, we put small adhesive feet on the 580 cards to space them from other cards. Works great on our remaining 5,1s.
Hugh
Old 05-16-2021, 12:25 PM
the.engineer the.engineer is offline
Coffee stirrers!
James Welch
Recording Engineer | Producer
Masterlink Productions
Mac Pro 5,1 (Mid 2010) | 3.46GHz Six-Core Intel Xeon | 32GB Ram | AMD Radeon R9 280X 3072 MB | 256GB Samsung SM951 SSD Blade (PCIe) System Drive | 1TB WDC Sample Drive | 4TB RAID 0 Seagate Audio Drive | UAD-2 Quad PCIe
Mojave 10.14.5 | Pro Tools Ultimate 2019.5 | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
James Welch
Mac Mini 8,1 (2018) | 3.2 GHz 6-Core Intel i7 | 64GB Ram | Apple 27" LED Cinema | 2TB System Drive | LaCie Rugged USB-C 2TB SSD NVMe Audio Drive | UAD-2 Quad Satellite (Firewire)
macOS Catalina 10.15.7 | Pro Tools Ultimate 2021.7 | Avid HDX TB3 Chassis | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
Radeon RX580 video card musicman691 General Discussion 7 04-28-2021 02:40 PM
Anyone added ATA-66 card in G4 867/Mix Plus for add'n IDE data drives? el biciclista Pro Tools TDM Systems (Mac) 2 06-02-2002 08:54 AM
Dual Monitor card+ Video Playback card? NK Pro Tools TDM Systems (Mac) 7 05-22-2001 12:27 AM
re: VIDEO CAPTURE, Fuse card is approved but will Igniter card work as well? ragbor Pro Tools TDM Systems (Mac) 0 12-08-2000 11:56 AM
Yikes G4 monitor card uno1234 Pro Tools TDM Systems (Mac) 2 08-21-2000 01:35 PM
