does anyone here know why whenever i would bounce the wave files into mp3 or wave, the file itself has no sound in it?
MacBook Pro 15" Mid 2012 2.3 GHz IntelCore i7, Intel HD Graphics 4000 1024mb, 16gb RAM 1600mhz DDR3, 512SSD Samsung 840 Pro, Maverick, Pro Tools 11.3.1/10.3.9, Superior Drummer 2.3.4, Axe-Fx II, Mbox 2 Pro Last edited by DigiTechSupt; 08-27-2014 at 03:30 PM. Reason: Off topic moved from "Bouncing in PT11 - Can't see existing files" thread. |
![]() Quote:
Double-check that bounce window and I bet your problem is found right there.
![]() Quote:
Now that was a funny one....Only the reverb bus in the bounce file. ![]()
Jay-J System MacPro 12 Core • 24 G Ram • 10.12.6 PT 12.8.1 • Mbox 3 Pro • Plug-ins Verified 4 HD • OS ssd | Audio ssd | Sample Library ssd | Storage MAXPower eSATA 6G Card • Wiebetech RTX100H-Q Kensington Trackball Works/Orbit Optical Bluetooth off/Airport on and off. |
![]() Quote:
MacBook Pro 15" Mid 2012 2.3 GHz IntelCore i7, Intel HD Graphics 4000 1024mb, 16gb RAM 1600mhz DDR3, 512SSD Samsung 840 Pro, Maverick, Pro Tools 11.3.1/10.3.9, Superior Drummer 2.3.4, Axe-Fx II, Mbox 2 Pro |
Probably something changed in the i/o setup, that can happen.
Luckily it is easy to fix (in the i/o setup window) and then as you found out, re-selecting outputs in the mix window fixes the routing. Did you know that holding alt key while choosing output makes it happen for all tracks?
Markers in Bounced Audio Files | David Every | Pro Tools 11 | 0 | 08-06-2013 09:12 PM |
Pop at the end of bounced files | brickroadstudio | Pro Tools HDX & HD Native Systems (Mac) | 11 | 07-25-2011 06:42 PM |
Can't hear bounced audio files from PT 8, 003 Rack | girascopic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-28-2009 02:41 PM |
Bounced files end gets cut off | breakie | Pro Tools TDM Systems (Mac) | 8 | 05-25-2005 01:26 PM |
Bounced files | shameeta | General Discussion | 4 | 11-09-2003 07:36 PM |
