Old 11-21-2011, 03:45 PM
bryced87 bryced87 is offline
Default Monitor level question
Hello
I just got some monitors finally. I am wondering how loud they should be. Does the level of them make any difference with what I'm hearing while I'm in the final mixing stage?
Old 11-21-2011, 04:18 PM
Craig F Craig F is offline
Default Re: Monitor level question
yes it matters
to low and you may over load your recoding level
to high and your may get ear fatigue and/or under record you levels
get a SLP meter and some band limited pink noise (if you can't find BL Pink, use the full pink signal generator and put step HPF/LPF at 500Hz and 2kHz) you will want between 75 dB SLP and 85 dB SPL at the opium listing postion per speaker depending on the size of your room and how close they are to you
(yes, this is the simplified version)
Thank you,
Craig
Old 11-21-2011, 04:22 PM
dr sound's Avatar
dr sound dr sound is offline
Originally Posted by bryced87 View Post
Hello
Go here and read this and follow the directions:
http://duc.avid.com/showthread.php?t=87830
Marti D. Humphrey CAS
aka dr.sound
www.thedubstage.com
IMDB http://www.imdb.com/name/nm0401937/
Like everything in life, there are no guarantees just opportunities.
Old 11-21-2011, 05:07 PM
Do I have to buy a spl meter? I really don't have anymore money to spend.
Old 11-21-2011, 05:24 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Buy one from Radio Shack, it's like $40. If you HAVE to, return it later that day. You'll need it in the future, when you upgrade to a surround system.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 11-21-2011, 05:34 PM
iPhone SLP Meter app is good also
Thank you,
Craig
Old 11-21-2011, 06:23 PM
Okay thanks, I read through the articles. I downloaded a pink noise file. I'm still unsure as to whether I should play this file in another program or if I can play it in pro tools. Wouldn't playing it in pro tools and adjusting the master fader mess up my SPL reading?
Old 11-21-2011, 08:20 PM
you don't adjust anything in PT
only your main volume knob and speaker trims
if your are using your Mater Faster as your volume control you need to get a proper monitoring system
Thank you,
Craig
Old 11-21-2011, 08:23 PM
Okay
I dont' really understand what you mean. I got m audio studio monitors. I have used lynda which is a tutorial site for software it clearly explains how using the master fader properly adjusts the volume mix. Is this without monitors?I've spent 300 dollars on these monitors and now I'm afraid I don't know how to use them properly. Is there a video tutorial that explains how to do this?
Old 11-21-2011, 08:33 PM
you should have a device like these that has a volume knob on it
http://www.sweetwater.com/c417--Monitor_Management
Using the Master Fader to adjust speaker level affects any file that is being produced from it (ether an output or a bounce)
Normally you want to keep that as untouched as posable
Thank you,
Craig
[IMG] code is Off
Question on mix bus level and my monitoring level dilemma bukman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 19 10-20-2009 05:06 PM
Monitor level (knob) question Pedro perez 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-17-2005 01:25 PM
Digi 001 Monitor Outs level question RobbaDobba 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-26-2005 06:38 AM
Monitor Level BrianD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-14-2003 01:41 PM
Control24 Monitor level Freddie ProControl, Control|24, Command|8 1 04-04-2001 09:50 AM
