Old 03-28-2023, 10:19 AM
kkfaudio kkfaudio is offline
Default Field Recorder Channel Names
I'm curious where/how the metadata for Channel names comes from.
I receive all of the audio via AAF, usually Media Composer, and often find that the channel names displayed are incorrect - ie Channel A3 shows channel name "Boom" but really it's "Don", A4 shows "Don" but really it's "Sally".
75% (?) of the time, the names are correct but enough is incorrect that I need to take the time to make sure I'm selecting the proper clip, or go by Track Channel A3/A4, etc - but that can change on different shoot days with the same people.
Is this all on the location sound person to get right, or is does it have to do with how it's imported into MC?
Just curious if where this breaks down.
Really not a huge issue - but it would be nice if we could rely on that info...
Thanks!
Kevin Ferrier
Audio & Sound Design
www.jaxxcreative.com
Old 03-28-2023, 12:12 PM
BScout BScout is offline
Default Re: Field Recorder Channel Names
The issue is with the location sound person. That's where the data is put in and it isn't altered after that unless someone went in specifically and changed the channel names in Media Composer (but it would have to be intentional.)
Pro Tools Ult 2023.3, RME BBF Pro + MADIface ProMac Mini 14,12 - 12 core - macOS 13.3.1RAM 32GB, SSD 4TB, GPU 19 coreQNAP TVS-872XT 148TB TB3
Pro Tools Ult 2022.7, HDX 3, MTRX/SPQ, HD OmniS1 x 2, FireHD x 2, Dock, iPad Mac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 4TB, GPU GTX 980 4GB
Old 03-28-2023, 02:34 PM
mfranken's Avatar
mfranken mfranken is offline
Sounds In Sync
I've noticed incorrect channel names in AAFs exported from MC. This wasn't caused by the sound recordist setting the channel names incorrectly as loading the original poly WAVs into Pro Tools showed that the metadata was set correctly. Either MC didn't translate the metadata correctly while importing the WAV files, or while exporting the AAF. From memory I think it had something to do with poly WAVs that had mute channels or a channel sequence where the recordist had say recorded A1, A2, A4, A6. In this case I think MC wasn't assigning the channel names by the actual channel number, but by channel count.
This is one of the reasons you might consider assembling a PT session using the original location WAVs so the correct metadata is loaded, and to make sure all channels that were recorded on location are available. For more information check out the new EdiLoad Assembly window that I created. A full demo video is available in this blog post.
Best regards,
Mark
Mark Franken, MPSE
Dialogue editor/supervisor IMDb
Creator of 'EDI' applications for sound post editors
www.soundsinsync.com
Old 03-28-2023, 03:01 PM
Thanks for that insight, Mark.
These are generally HGTV type renovation shows and time is tighter than ideal to manage that workflow - I would love to, but :-(
And in truth, it’s just a slight annoyance and I was mostly just being curious curious the cause.
Kevin Ferrier
HTML code is On
Field Recorder Workflow with Live PT sessions as Field Recordings SlickSlack Post - Surround - Video 9 11-10-2022 05:45 AM
Replacing a Clip with a Matching Segment from a Matching Field Recorder Channel srdm77 Pro Tools 2020 6 12-31-2020 01:22 AM
Field Recorder Matching Channels Resulting in Wrong Channel Name Felix Andriessens Post - Surround - Video 3 06-05-2019 11:47 AM
Any ideas on channel spill for Field Recorder "Functionality"? Ray JB Post - Surround - Video 24 06-14-2016 05:21 PM
Field recorder channel and play lists grant howarth Pro Tools 10 6 01-03-2012 06:43 AM
