Old 01-14-2003, 06:51 PM
sequence025 sequence025 is offline
Default Problem opening sessions
Hi all,
having problems opening a session which contains audio files I imported from cubase.Each time I open the session ProTools LE ask to locate the audio files, which I do ,then I get a message saying kick.L is not on a valid audio drive(which it is).The end of the story is the file gets copied to the session audio folder every time I open or save the session(resulting in many copies of the same file).Audio which I have recorded into the session does not do this.I am using a firewire drive for my ProTools files(Lacie d2).Can anyobody help.
Cheers Peter
Old 01-14-2003, 08:09 PM
Default Re: Problem opening sessions
Hi All,
sorted.Disabled lacie driver extensions.Should I reformat drive using erase disk command on Apple Special Menu just to be on the safe side,as I originally formatted drive using lacie Silverling Pro that came with the drive?
Cheers Peter
Yes.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Problem opening sessions out of nowhere mdb123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-08-2011 04:20 PM
Problem opening big sessions. JD85 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-19-2010 05:53 PM
PT7 problem opening old sessions gerax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-22-2005 05:35 PM
**Problem: Certain sessions crash on opening... DustySpuds 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-04-2005 09:51 AM
Problem opening 5.1 sessions with 5.1.1 jeffreyc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-04-2001 09:19 PM
