DADman monitor profile loses saved settings on restart
Hi!
On installing software on my new Mac Studio 12.5.1 with MTRX, I came across a weird bug with DADman 5.6.3.8 (or so it seems...): When I finish programming my monitoring setup in Monitor Profile and save the file, on re-load several of the routings and custom names given to particular inputs and outputs are ignored, leaving them empty in the profile setup. What to do? Regards, Javed Kurd Oslo, Norway |
Re: DADman monitor profile loses saved settings on restart
Check file/folder permissions.
Try resaving a new profile to a new folder.
James Richmond https://www.jamesrichmond.com 2019 Mac Pro, 2022 Mac Studio Ultra Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro. Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com Latest Article: Auto-Bounce for Logic Pro Affiliate Links: Auto-Bounce by Tom Salta Dreamhost Web Hosting |
G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.5, DP 11.3, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS |
Greetings,
Are you 100% sure you are performing a File > Save Profile As (.dmprof) and not Save > File As (.dms)? They are independent files that need to be managed separately. Also - agree with the permissions check. I would recommend storing your DADman data files under a path such as Users/Documents/DADman/ Jeff |
Hi, Jeff, and thanks for chiming in!
Yes, as a longtime user of DAD hardware, I’m well aware that the are two sets of files. I’ve also paid special attention to the saving procedure, to make sure that files are actually saved properly. The file creation time and date is updated for every save. J. Sent from my iPhone using Tapatalk |
Understood. If you've checked the files, permissions and save dates - you may want to try making a new empty monitor profile -> then use Settings > Monitor Profile > Import from Profile to bring in all of your current bits including Sources, Outputs with trims and tunings, Folddowns, etc.
For best practices, don't set DADman to auto-launch when the computer boots unless you have the appropriate delays inserted. Once booted, you should have DADman set to auto-restore both .dms and .dmprof. Let us know. Jeff |
Later, G
Hi again!
I've tried saving to different locations and disks, but still faulty recall on some of the monitor profile outputs. I have, however, narrowed it down to one set of particular speaker outputs, the 8 routings from MADI module 2 beginning at channel 17 and upwards. Labels stay connected to the particular sources and outputs, but it is the assignments of those 8 outputs that are lost. Any ideas? The workaround is to manually assign those particular outputs on every reboot, but it's kind of tedious and can, if not careful enough, give very unpleasant and dangerous soundlehvels coming from the unassigned speakers. Thank you again for your help here! Javed Kurd, Oslo Norway. |
Hey there! Can you share your solution for this? We are experiencing the same issue using a MTRX with DADman software for macOS Ver. 5.6.3 build 8. Any info would be greatly appreciated!
DADman MTRX Monitor profile loading | AINSLIE | Pro Tools | MTRX & MTRX Studio | 9 | 02-19-2022 03:29 PM |
DADman Monitor not restoring | B-Grade | Pro Tools HDX & HD Native Systems (Mac) | 12 | 10-10-2020 02:22 PM |
DADman MTRX profile question | SomeOtherGuy | Pro Tools | MTRX & MTRX Studio | 18 | 07-20-2020 10:26 AM |
plugin settings not saved at restart??! | Studio820 | Windows | 8 | 02-09-2015 06:56 AM |
Kensington Mouseworks loses settings when opening PT | SATP | Pro Tools TDM Systems (Mac) | 2 | 06-05-2008 09:41 AM |
