Hi all,
Two points: 1 - If I close Pro Tools 10 (PC, win7) and want to reopen these, I get a message that it is closed incorrectly and I have to restart the computer. I seem to have encountered this problem at the time of PT8, but I could not remember the solution. I have not found anything on the site or on the forum. I have perhaps not the right words in English. 2 - One way is not to lose its ![]() thank you. |
Can you give LESS info? Check this thread from the top section of the page:
Help us Help You - READ THIS Before Posting! then post a Sandra report and what interface you have.
Gigabyte X79/intel i7 3930K, 32GB RAM, HD/Native, 192 IO https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave |
Okay, if it can help. But according to my recollection, this beast is a detail related to Windows. Otherwise, Harware side, the only addition is a UAD DSP CORE DUO.
Thanks ! SiSoftware Sandra ID Nom de l'Hôte : studio Groupe de Travail : WORKGROUP Système Modèle : GigaByte X58A-UD3R Chassis Système : GigaByte Ordinateur de Bureau Carte mère : GigaByte X58A-UD3R BIOS Système : Award (OEM) F6 08/24/2010 Mémoire Totale : 16Go DIMM DDR3 Processeurs Processeur : Intel(R) Core(TM) i7 CPU 930 @ 2.80GHz (4C 8T 3GHz, 2.16GHz IMC, 4x 256ko L2, 8Mo L3) Prise/Connecteur : FC LGA1366 Chipset Contrôleur de Mémoire : Gigabyte X58 I/O Hub 2x 2.43GHz (4.86GHz) Contrôleur de Mémoire : Gigabyte Core Desktop (Bloomfield) UnCore 2x 2.43GHz (4.86GHz), 3x 5.33Go DIMM DDR3 1.08GHz 192-bit Module(s) de Mémoire Module de Mémoire : Corsair CMX8GX3M4A1600C9 2Go DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Module de Mémoire : Corsair CMX8GX3M4A1600C9 2Go DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Module de Mémoire : Corsair CMX8GX3M4A1600C9 2Go DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Module de Mémoire : Corsair CMX8GX3M4A1600C9 2Go DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Module de Mémoire : Corsair CMX8GX3M2A1600C9 4Go DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Module de Mémoire : Corsair CMX8GX3M2A1600C9 4Go DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Système Vidéo Moniteur : (Types d’écrans standard) Moniteur non Plug-and-Play générique Moniteur : LG (1600x1200, 17.1") Adaptateur Vidéo : NVIDIA GeForce GT 430 (2CU 96SP SM5.0 1.4GHz, 1Go 1.33GHz 128-bit, PCIe 2.00 x16) Adaptateur Vidéo : NVIDIA GeForce GT 430 (2CU 96SP SM5.0 1.4GHz, 1Go 1.33GHz 128-bit, PCIe 2.00 x16) Processeurs Graphiques Processeur OpenCL : NVIDIA GeForce GT 430 (96SP 2C 1.4GHz, 1Go 1.33GHz 128-bit) Processeur Compute Shader : NVIDIA GeForce GT 430 (96SP 1.4GHz, 1Go 1.33GHz 128-bit) Processeur CUDA : NVIDIA GeForce GT 430 (96SP 2C 1.4GHz, 128ko L2, 1Go 1.33GHz 128-bit) Dispositifs de Stockage Physiques WDC WD1003FBYX-01Y7B0 (1To, SATA300, 3.5", 7200rpm) : 932Go (B:) (C:) WDC WD5001AALS-00J7B1 (500.1Go, SATA300, 3.5", 7200rpm, 32Mo Cache) : 466Go (F:) WDC WD5001AALS-00J7B1 (500.1Go, SATA300, 3.5", 7200rpm, 32Mo Cache) : 466Go (E:) Seagate ST31000528AS (1To, SATA300, 3.5", 7200rpm) : 932Go (D:) SanDisk Cruzer Edge (8Go, USB2) : 7Go (H:) Seagate ST31000528AS (1To, USB2/SATA300, 3.5", 7200rpm) : 932Go (G:) Dispositifs de Stockage Logiques Réservé au système : 100Mo (NTFS) Brass-etc (F:) : 466Go (NTFS) @ WDC WD5001AALS-00J7B1 (500.1Go, SATA300, 3.5", 7200rpm, 32Mo Cache) Strings (E:) : 466Go (NTFS) @ WDC WD5001AALS-00J7B1 (500.1Go, SATA300, 3.5", 7200rpm, 32Mo Cache) Sessions (D:) : 932Go (NTFS) @ Seagate ST31000528AS (1To, SATA300, 3.5", 7200rpm) Lecteur Amovible (H:) : 7Go (FAT32) @ SanDisk Cruzer Edge (8Go, USB2) Disque 1T (G:) : 932Go (NTFS) @ Seagate ST31000528AS (1To, USB2/SATA300, 3.5", 7200rpm) Programmes (C:) : 488Go (NTFS) @ WDC WD1003FBYX-01Y7B0 (1To, SATA300, 3.5", 7200rpm) Partition (B:) : 444Go (NTFS) @ WDC WD1003FBYX-01Y7B0 (1To, SATA300, 3.5", 7200rpm) Périphériques Contrôleur Hub LPC 1 : Gigabyte LPC Interface Controller Contrôleur Hérité LPC 1 : ITE IT8720F Périphérique Audio : ZOTAC International (MCO) GF108 High Definition Audio Controller Périphérique Audio : 6656 0001Universal Audio UAD-2 Duo Contrôleur de Disque : Gigabyte 4 port SATA IDE Controller Contrôleur de Disque : Gigabyte 2 port SATA IDE Controller Contrôleur de Disque : Gigabyte 88SE91A3 SATA-600 Controller Contrôleur de Disque : Gigabyte JMB36X PCIE-to-SATAII/IDE RAID Controller Contrôleur de Disque : Gigabyte JMB36X PCIE-to-SATAII/IDE RAID Controller Contrôleur USB 1 : Gigabyte USB UHCI Controller #4 Contrôleur USB 2 : Gigabyte USB UHCI Controller #5 Contrôleur USB 3 : Gigabyte USB UHCI Controller #6 Contrôleur USB 4 : Gigabyte USB EHCI Controller #2 Contrôleur USB 5 : Gigabyte USB UHCI Controller #1 Contrôleur USB 6 : Gigabyte USB UHCI Controller #2 Contrôleur USB 7 : Gigabyte USB UHCI Controller #3 Contrôleur USB 8 : Gigabyte USB EHCI Controller #1 Contrôleur FireWire/1394 1 : Gigabyte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller Contrôleur SMBus Système 1 : Intel ICH SMBus Imprimantes et Fax Imprimante : Microsoft XPS Document Writer (600x600, Rendu des Couleurs) Imprimante : hp color LaserJet 2550 PS (600x600, Rendu des Couleurs) Fax : Microsoft Shared Fax Driver (200x200) Imprimante : Adobe PDF Converter (4000x4000, Rendu des Couleurs) Périphériques Media Player : SanDisk Cruzer Edge (7.45Go) Services Réseau Adaptateur(s) Réseau(x) : Realtek PCIe GBE Family Controller (Ethernet, 100Mbps) Système(s) d'Exploitation Système Windows : Microsoft Windows 7 Professionnel 6.01.7601 (Service Pack 1) Compatibilité de Plate-forme : x64 Indice de Performance Windows Système Actuel : 5.9 |
There are a couple threads related to this i believe. One of which I started. I think it has to do with something on the particular PT release. It does not do this with earlier versions of PT10.
http://duc.avid.com/showthread.php?t=331045 Yo Albee...chill out with the sarcasm..we are all on here trying to help each other right?
Windows 7 64 Ultimate: SP1 PT 10.3.8 ------------------------------------------------------ ¨WHERE´S MY CHECKBOOK?¨ https://soundcloud.com/louieshowers |
Thank you Louie. I do 'not deal with sarcasm
You are welcome! I know your English is limited, but I didn't completely understand all of what you wrote. I am willing to say that this is another bug (protools closing and exiting) affecting SOME users on Windows 7. So we will hope that Avid acknowledges the issue and fixes it in another release.
I don't understand why experienced Protools troubleshooters and users on this DUC act so entitled and annoyed by users who are clearly struggling. I was attacked for almost 6 months by these "guru" types over a Windows GUI freeze issue which affected hundreds of Windows 7 users at that time....People were telling me I was irresponsible and did not use due diligence when setting up my system, that I was whining and looking for a free handout and that i essentially had a crappy computer. However, they all stayed quiet once Avid claimed responsibility and fixed it in a new release/rewrite of Ptools. FWIW
My English has an "Google translate" accent ! I'm French. Thank you.
haha...Ironically I am partially French Canadian , but do not speak one word of French! I hope this gets fixed.
There are 1 million French-Canadian immigrants to the United States for 200 years. I imagine the number of descendants!
Okay, back to the art. I went on the UAD forum and all sorts of problems finally arrive with Pro Tools and UAD cards. I do not understand why the support of each side, not assumed. That said, it is not clear whether "DSUs". Like I said, I had this problem before, but "DSUs" at the time of version 8. I hope that someone will respond. |
Pro Tools Crash on Save/Autosave | WestPhillySoulzition | Pro Tools 10 | 10 | 12-16-2022 05:45 PM |
Save Preferences | chaosdemonz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-12-2012 11:22 AM |
Save Preferences | chaosdemonz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-11-2012 03:18 PM |
Can't save with 'tracks' window closed? | RaySoul | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 12-23-2009 06:27 PM |
Can't Save Preferences | migel$ | Pro Tools M-Powered (Win) | 1 | 03-28-2009 05:06 PM |
