Old 02-20-2010, 06:10 PM
GordonFreeman GordonFreeman is offline
Default Digi 003 Rack Monitor Volume - crackling pot
Hi y'all!
I have had the Monitor pot making some crackly noises, so I tried what every studio tech tries first - Deoxit.
Well... that worked for about a day, and now it's even worse! I had this problem before with an old Mindprint interface, a while ago (but that one was a lot cheaper, so I just upgraded my gear).
What are my options? If I need to get this Monitor pot replaced, is there anything I should know beforehand, like the exact model number for the pots used on an 003 R?
Thanks in advance
Software:
Pro Tools 10.3.1, OS X 10.6.8;
Computer Hardware:
Mac Pro Quad 2.66, 20 GB RAM;
Audio/MIDI Hardware:
RME Fireface UC, M-Audio Keystation 88es + Akai LPK25 (USB);
Old 02-21-2010, 04:36 PM
Default Re: Digi 003 Rack Monitor Volume - crackling pot
Are the 003 Rack potentiometers sealed?
Maybe the Deoxit didn't even penetrate it! In that case, who can replace these?
This can't be that rare. Surely there must be people out there who have had the same problem.... Right?
Software:
Computer Hardware:
Old 02-21-2010, 04:44 PM
necjamc necjamc is offline
After recently replacing the pot's on my Marshall amp I'm willing to bet you need to find out the exact replacement for the pot. Taper, size etc. I have found that cleaning sometimes is useless because it just makes the dust stick together and get's spottier. Unless you can really blow it out, but that's not always good either.
Old 02-21-2010, 04:58 PM
I think these pots are sealed...
amps and electric guitars have vintage-style, open pots that are easy to clean - I spray my guitars and basses with Deoxit.
Newer equipment, like Digidesign rack gear, apparently uses sealed pots, to make it harder for tech engineers and savvy users to just clean it, and require an expensive repair from Digidesign... lol
I am basically waiting for a response from DigiTechSupt or the likes, telling me what model it is, if they are sealed, and how much Digidesign, or a representative, would charge to replace 2 or 3 pots in my 003 Rack.
Google has no information on this. At all.
Come on, can't really be that unheard of... In 2010, with the advent of twitter and google wave, there should be entire forums dedicated to tricks and hacks on how to get a dose of Deoxit penetrated into 003 Rack pots...
Software:
Computer Hardware:
Old 02-21-2010, 05:07 PM
Yes you would think so.
Old 02-21-2010, 05:34 PM
Hmm, indeed.
Software:
Computer Hardware:
Old 02-21-2010, 05:41 PM
Half Life I assume? Gordon
Old 02-21-2010, 05:49 PM
Hmm, indeed.
Software:
Computer Hardware:
Old 02-21-2010, 06:34 PM
Try to find an authorized Avid service center as they should be able to order replacement pots, or get you a part number for DigiKey(a great parts source not tied to Digidesign, despite the name similarity). Another option is to use a monitor controller like the Presonus Central Station so you can adjust the volume on that and not touch the cheap pots on the 003. I"ve had my CS for 3 years now and the pot is still quiet and smooth.
Old 02-21-2010, 07:23 PM
Yeah, a lot of people would love a Presonus Central Station.
But it's $500, so only people with money to waste (or irresponsible credit card management) can afford to buy a new rack device to compensate for the flaws of another expensive device they already own... :)
Software:
Computer Hardware:
Digi 003 rack: how to monitor with headphones rberks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-21-2008 07:19 PM
Crackling Audio & Glitches when using Digi 002 Rack + DP5 darkgoob 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-23-2007 02:28 PM
Volume from Digi 002 rack too loud. George Siede 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-08-2005 04:32 PM
002 Rack Monitor Output Volume Fluctuation rdatman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-19-2005 12:50 AM
HELP with Digi 002 ALT monitor outputs?? NO VOLUME Johnny916 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-10-2004 07:33 AM
