Old 02-05-2023, 12:12 PM
RichrdC RichrdC is offline
Default A Mixing Question
Hello to all.
So, you've been working on the volume of a particular instrument in a mix. You've made your adjustments up and down as the session plays through.. You get to the end and you like the small changes made as you listen, but realize you'd like the entire overall level to be something less than it is.
My question is, without changing any of the small adjustments you've made, is there a way of adjusting the entire instrument track's volume down a certain amount? Is there a command screen that you can get too where you can enter a volume decrease that will then move the entire strip the amount you want?
Thanks for any insights..
Old 02-05-2023, 01:06 PM
Default Re: A Mixing Question
The nice thing with audio is there are many ways to do anything. And what way to do this might depend on lots of stuff like other plugins/effects you are using and overall workflow.
You can just insert a Trim plugin at the end of the plugin chain for what you are doing and turn the level down in that plugin. That's a very traditional use of the Trim plugin and maybe the easiest way here.
Other approaches could include routing signals though an Aux track and pulling the level down on the Aux fader... that's maybe more useful if you have multiple instruments to bus together and you want to adjust the level of those (and maybe apply the same effect plugins) together
You could print the track to a file, or commit it (and include volume automation in the commit) and then adjust the clip gain or fader level on that track.
And if you want to do adjustments in the volume automation layer you can select the volume automation points you want and move them up and down with the trimmer tool.
That's enough for starters.
Old 02-05-2023, 01:17 PM
its2loud its2loud is offline
In addition, automation Trim mode will achieve what you are desiring.
Show the automation volume trim lane on the track and adjust the trim accordingly or write to the entire selection.
Old 02-05-2023, 02:54 PM
EGS's Avatar
EGS EGS is offline
Originally Posted by Darryl Ramm View Post
... just insert a Trim plugin ...
+1
Click for audio/video demo
Click for resume
Old 02-05-2023, 03:07 PM
Oh and Automation Trim mode as well. A truly lovely thing to play with, neat UI once you understand it, or a wonderful thing to confuse the heck out of people who notice the automation button is yellow and the automation UI has "gone crazy"
Ah thinking I should have said that as well... and then looked for the Volume Trim lane and it was not there in my edit window. What the !@#$%, took a few minutes to realized I had unplugged my iLok and Pro Tools was running as Pro Tools Intro.. with no Volume Trim.
Old 02-05-2023, 04:33 PM
Lots of good advice already. Yep, several ways to reach this goal. I start by considering the plugins on the track. Many will have an output control and that is another spot for a simple over-all change to volume(especially the last plugin on the track). For myself, I already have the TRIM plugin in the last slot on every audio or instrument track, so that's another easy grab for me. Just remember to consider what might be happening AFTER one of these adjustments(just in case it changes how some dynamics plugin might be affected)
Old 02-05-2023, 08:08 PM
My Goodness!!
Thanks to all of you.. I've got some editing fun coming up!! Great info to work through on my quest, as a hobbyist, to understand Pro Tools... I probably need a couple more lifetimes, but it sure is a lotta fun knowing there are those out there who know their stuff.. thanks again to all!!
Take care
Old 02-23-2023, 10:43 AM
take77 take77 is offline
Originally Posted by RichrdC View Post
My Goodness!!
Take care
I feel your excitement.
As Darryl says, there's more than one way to achieve audio ends. So it's all about learning and knowing your options.
Pro Tools has many of those allowing you to develop your own workflow.
Such a vast and multi-faceted program. You'll never get tired of it if you're the true creative type.
Learning the various tools within PT empowers you with creative & expressive control over anything you want to do.
If you can conceive it, PT is an enabler to achieve it.
All with a view to to achieving whatever desired end you envision.
A rough sea makes a smooth sailor.
Pro Tools Studio 2022.7|Windows 10 22H2|Focusrite Scarlett 2i2 (2nd Gen)|Dell Inspiron 3650|Intel i5 6th gen|16GB RAM|Samsung T5 SSD's|Hitachi|Touro HDD
Toontrack EZdrummer 3|Steven Slate Drums 5.5 + Blackbird Studio EX|Spectrasonics Trilian|Native Instruments Guitar Rig 6
Waves|SSL Native|Fabfilter|Softube|Soundtoys|Nomad Factory
Mixing Question ... help! TDub 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-24-2010 11:13 AM
Another 5.1 mixing question Peter Groom Pro Tools TDM Systems (Mac) 1 08-11-2009 06:02 PM
Question on Mixing LSJ Pro Tools TDM Systems (Mac) 3 05-09-2008 03:51 AM
Mixing Question Raoul2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-27-2004 09:34 PM
Another mixing question, I think... Bezo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-12-2003 03:46 PM
