According to the manual
Session Plug-In Settings Folder (Sessions Only) When this option is selected, the session’s Plug-In Settings folder is copied to the new location. The references to these settings in the session are redi- rected to the copied settings files. Root Plug-In Settings Folder (Sessions Only) When this option is selected, the contents of the root-level Plug-In Settings Folder are copied into a folder named Place in Root Settings Folder, indi- cating that these files will need to be moved to the root level plug-in settings folder on the destination system before you can use them. The references to these settings files in the session are not redirected to point to the copied files. When would we actually use this? |
They already wrote most of the answer here:
http://duc.avid.com/showthread.php?t=177163 Basically, IF or WHEN you move sessions to a new computer, or plug-in settings from an old session to your current one, this comes into play. It is possible to, say, have your default presets in your own computer's "root plug in settings folder" but if someone on another computer sent you a session and they saved their project settings (properly), you could import data from that session (without opening the session), including the presets/settings that other computer carried along in the Session Settings Folder (i.e. without sending their own root settings in entirety). So there are reasons to do this, but for specific workflows. If you are always on your own computer and you never share sessions with anybody, put every preset you want to recall in your root.... probably. Someone else might tell you there is sometimes a reason to do it even if it's just your computer, but at least the reasons I gave above indicate why it might be useful to separate the settings folders.
___ >> me: nednednerB // ||main gig: editing audio & testing software / 2nd gig: music software tutoring // ||software: Ventura 13.2.1 | PT Studio 2023.3 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 // ||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB // ||devices: Focusrite Clarett 2Pre | some AT condenser mics | SM58 | Ableton Push 2 | 32" 4k LG secondary display // ||automation: SoundFlow | Keyboard Maestro | SteerMouse // |
"Save plugin settings to session folder"...and repeat? [solved] | Ticker | Pro Tools 12 | 3 | 07-12-2021 08:10 PM |
"Digidesign Midi I/О" in "ProTools 10HD" in "OSX Maverics" | electra1006 | MIDI | 0 | 06-18-2018 05:46 AM |
"cannot save "XXXXXX" because while translating I/O settings" | tdawgg | Pro Tools 10 | 14 | 10-26-2013 02:27 PM |
Save as > "Could not 14404 because File or folder not found (-43) while opening "..." | Elias Stiza | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-10-2012 07:06 PM |
Import session data... please break out "plug in settings" and "plug in automation" | yeloocevad | Pro Tools TDM Systems (Mac) | 19 | 10-05-2011 01:04 PM |
