Old 05-26-2021, 12:58 AM
mfranken's Avatar
mfranken mfranken is offline
Sounds In Sync
Default Re: EdiCue v3 released
Just released #EdiCue v3.4.0. This version includes the following updates:
  • New Filter controls on the 'General Settings' tab.
  • Updates to how PDF scripts are loaded into the Session Interface window.
  • Change to message displayed after an AAF is exported to show settings required in Pro Tools including fixes made in PT2021.3.
  • Fix for changes made in v3.3.0 so all fields in the Session Interface window are cleared when you get the data from a clip.
  • Added an 'Open Folder' button to the message displayed on completion of an export to reveal exported files in the Finder/Explorer.
  • Updates to allow non-English text to be entered into the ADR Reason list and Session Interface 'Cue Status' and 'New Reason' fields.
  • Custom Cue Numbers are now shown in the 'Cue Details' window when Pro Tools text files are loaded.
  • Added check while loading Pro Tools text files for '.dup' tracks that have no base cue track.
  • Fix in the 'Create Template AAF - Track Names' window so the list is compatible macOS dark mode.
  • Bug fix so a New Line tag at the start of the Line field is read.
  • While importing data from Excel files hidden tabs are now ignored.
To download the app installer, go to http://www.soundsinsync.com/download/
Mark Franken, MPSE
Dialogue editor/supervisor IMDb
Creator of 'EDI' applications for sound post editors
Old 10-19-2021, 11:19 PM
mfranken's Avatar
Sounds In Sync
Just released #EdiCue v3.4.1. This version includes the following updates:
  • Fix to Session Interface window to make sure that text sent to Pro Tools clip name does not contain hidden control characters which can break the import of data from an EdiCue PDF.
  • Increased the maximum number of characters that can be stored in the 'Segment Picture Version' field from 12 to 20 characters.
  • For Department Notes the 'Cue Status' field data is now shown in exported PDFs.
  • Changes to the Session Interface window to properly handle 'Line' text that starts with new lines.
Mark Franken, MPSE
Old 12-12-2021, 08:55 PM
mfranken's Avatar
Sounds In Sync
Just released #EdiCue v3.4.2. This version includes the following updates:
  • Following fields are now exported in the clip names of AAF exports: 'Cue Status', 'BVox', 'Safety Only', and 'PDF Editable'.
  • New 'PDF Editable' column in the 'Cue List' window.
  • 'PDF Editable' fields are now imported and exported in 'All Fields' Text and Excel files.
  • Fix so correct font style is printed in PDFs if any italics styling (tags) are setup in Line field.
  • Fix to stop crash when band designer formula editor is opened and changes are made.
  • Tweak so initial display of main window shows controls in correct location on macOS Monterey.
Mark Franken, MPSE
Old 01-05-2022, 09:58 PM
mfranken's Avatar
Sounds In Sync
Just released #EdiCue v3.4.3. This version includes the following updates:
  • Fix to read the extension of a file correctly when the filename contains non-English characters.
  • Bug fix so the menu item 'File > Load PDF Layout Test Data' now works again.
  • Fix so dropping a shooting script text file onto the Session Interface window now displays the script at the end of load.
Mark Franken, MPSE
[IMG] code is Off
EdiCue v3 - Emmy Award winning ADR cueing app major update has been released mfranken Partner Announcements 0 08-04-2019 09:16 PM
12.6 released!!! thanos4 Pro Tools 12 80 09-30-2016 08:13 AM
12.5.2 released MIKEROPHONICS Post - Surround - Video 5 07-09-2016 10:36 AM
Will 6.7 be released on Oct. 28? Imagine Pro Tools TDM Systems (Mac) 15 10-27-2004 01:03 AM
DP 4.5 Released! Imagine Pro Tools TDM Systems (Mac) 11 10-01-2004 04:42 AM
