Old 10-05-2014, 05:13 PM
Chingy Chingy is offline
Default Workspace Auto-play Latency
Hello,
Is there a way to improve the latency of auto-play in the workspace? I have auto-play on, but when I move through the samples using the arrow keys, it takes a second or so for the sample to actually play. Would be great if I could make it instantaneous - not sure if if it is only playing on the beat or something.
Cheers.
Old 10-15-2014, 12:05 PM
Shan's Avatar
Shan Shan is offline
Default Re: Workspace Auto-play Latency
Are the samples you audition stored on a separate drive or the main system drive?
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 10-15-2014, 06:39 PM
Separate, new 7200rpm drive. It doesn't cut off the playing sound, which means the next sound won't play until the previous sample ends (or so it seems) - or it is waiting for the next beat or something. Battery 4 in PT doesn't have this issue.
Old 10-17-2014, 07:25 AM
Shan's Avatar
One thing that comes to mind is there could be some dead space in front of the audio sample. Just throwing that one out there. Also, do you have loop preview selected?
Shane
Old 10-17-2014, 01:02 PM
Shifted Music's Avatar
Shifted Music Shifted Music is offline
The auto play in combination with Elastic audio to synch the loop prevue to the tempo has always worked like this for me.
When not in elastic audio synch i get playback fairly quickly. But it is depended on the drive and what not. I have a internal sample library on a WD caviar black which isn't the fastest by todays standards but does really well...
But when synching to the tempo it try and waits till a whole bar usually or the nearest beat.
and often isn't even correct so I have to re trigger if really trying to audition in context with the song.
I have found PT 11 to be better overall in this regard for SURE! but still sometime a bit laggy when synching to song tempo and previewing...
Jay-J
System
MacPro 12 Core • 24 G Ram • 10.12.6
PT 12.8.1 • Mbox 3 Pro • Plug-ins Verified
4 HD • OS ssd | Audio ssd | Sample Library ssd | Storage
MAXPower eSATA 6G Card • Wiebetech RTX100H-Q
Kensington Trackball Works/Orbit Optical
Bluetooth off/Airport on and off.
Old 10-17-2014, 08:28 PM
How do you disable Elastic Audio in workspace?
Old 10-18-2014, 06:44 AM
Drew Mazurek's Avatar
Deselect the Metronome icon.
www.drewmazurek.com
Old 10-18-2014, 01:51 PM
Looks like turning on Loop Preview fixed this. Without it one, Workspace seems to be delayed in terms of responding to keystrokes, but with it on, it is much more responsive with no latency. Strange behavior, but at least it worked! Thanks!
Old 10-18-2014, 02:39 PM
Shan's Avatar
Originally Posted by Shan View Post
...Also, do you have loop preview selected?
Shane
Good to hear you have it working now.
Shane
Play Sound in Finder - Clean; Play Sound in Workspace - Noisy LT_CJ macOS 6 03-16-2012 08:19 AM
Workspace Window - auto indexing issue TQ1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 04-01-2008 06:11 PM
Play audio from workspace through ADAT 1-2 output max cooper 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-10-2007 02:30 PM
XP Users, Disabling CD-Rom Auto Play??? Rudger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-26-2002 12:54 AM
auto play and toast Munxcub 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-24-2002 02:39 AM
