Old 10-25-2013, 10:38 PM
ilovemusic ilovemusic is offline
Default Recording latency varying between sessions ? ?
I just did a DA/AD loopback test in a session that contained only two audio tracks, one to play and one to record and I got a latency value in samples.
That latency value is consistent across all buffer sizes
However, when doing the same test in a busy arrangement, the value exactly doubles.
What is the reason for that ?
Thanks for any help
Using 11.0.2 HD Native, PC, Win 8, RME HDSPe AES
Old 10-26-2013, 07:00 AM
clausiii's Avatar
clausiii clausiii is offline
Default Re: Recording latency varying between sessions ? ?
Sessions have the same sample rate?
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 10-26-2013, 10:52 AM
Yes. 96k, 32-bit float
Old 10-27-2013, 04:45 PM
Different plugins in each session?
low latency recording vs low hardware buffer size recording chrisdee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 01-27-2009 06:49 AM
Varying delays between different preamps delta ICON & C|24 2 02-28-2006 09:51 AM
varying plug-in settings Hrishikesh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-29-2002 01:04 AM
Whats the difference between Low Latency recording and recording on low latency with Dead River Studio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-25-2002 01:22 PM
Varying speeds on playback Chicago 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-28-2001 05:32 AM
