Old 02-03-2010, 05:09 AM
DJLilSteve DJLilSteve is offline
Default Plug-In Will Only Show On Drop Down Menu
i have installed ssl 4000 1.2 and it will only show on the drop down menu on pro tools 6.4 le and will not allow me to put it on a channel by itself when before it did .... anyone know the deal ? do i need to unistall all waves n re install back ?
Old 02-03-2010, 08:21 AM
Default Re: Plug-In Will Only Show On Drop Down Menu
I would check with Waves and see if that plugin is compatible with 6.4 first. Then(assuming it IS) uninstall and try again.
Old 02-03-2010, 06:07 PM
well the thing is that i had version 1.1 and version 1.2 cause of the upgrade its suppose to be not compatible with 6.4 but soo when i went back to 1.1 it started not to show on any channels on the mixer .... is there any way i can delete everything like reg and try again cause for some reason i have a feeling the 2 plugins are at war with each other in the reg or somewhere...
Old 02-04-2010, 03:08 AM
i just unistalled all waves products and reinstalled them but still the same this is really getting on my nerves and i know its prolly something simple can someone please help me out .. im running windows xp sp2 basically the problem is that the plug in will only show on the drop down plugin menu and not in the channel plug in drop down menu .. and it did before
Old 02-04-2010, 03:56 AM
kinda weird almost every time i post here i solve my answer just takes lots of hrs lol ok i fixed the problem and im going to list it just in case someone needs it one day .. the problem was that the pref was telling the wave shell not to load the rtas soo i went to Application Data\Waves Audio\Preferences and found 5.7 which was the ssl plugin and viewed it in notepad and looked untill i saw RTAS "false" and i just typed in true and saved and reload and it found the plugin to be seen in both plugin menus ..
Old 02-04-2010, 08:44 AM
Good detective work. I bet you just missed the check box during the install.
Maschine 2 AAX does not show up in Plug-In Drop Down PT11 Demo johnnybregar Virtual Instruments 1 02-28-2014 12:41 PM
Plug Ins I have uninstalled still show in Plug Ins menu Robusto Windows 4 12-28-2013 01:43 PM
Favourites in PT Drop Menu ThisIsSick Tips & Tricks 1 09-26-2009 05:12 AM
Some plugins don't appear in drop down menu. lowfreq33 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-17-2006 07:41 PM
Waves Plugs show up twice in Plug Ins Menu Delusion 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-05-2003 08:35 PM
