Old 07-16-2021, 07:14 PM
dg27's Avatar
dg27 dg27 is offline
Default Clean install or update from 2020.3 to 2021.6?
I started getting very weird errors yesterday in PT 2020.3 (I have another post about that). Everything I've tried has failed and I think I'll just move from 2020.3 to 2021.6. I can't afford any more downtime.
I was going through previous posts and found this:
Originally Posted by albee1952 View Post
As always, these 2 tricks:
#1-Always have a backup plan. Drive imaging is the bare minimum. Cloning and swapping drives is even better(so the old version and system drive don't get messed up).
#2-UN-Install the older version before installing the newer version of Pro Tools. Things used to work as an update, but moving to 2020, it seems best(or mandatory) to uninstall the old version first.
I'm covered regarding #1.
Would #2 still apply going from 2020.3 to 2021.6 and I should clean install rather than update?
I have a few other questions:
Should I install the drivers before installing Pro Tools?
(I think yes, but honestly can't remember.)
Is the DX Driver 8.9.1 for HD only?
(I think all I need is CodecsPE 2.7.3.)
Do I need to install Legacy AIR Creative Collection Effects and Instruments and the Avid Virtual Instruments?
(I have sessions from older (PT12) versions. I think the First AIR bundles replace those, but I'm not sure. I don't want to lose an AIR instrument if I used it in older session).
I've copied these folders to another drive:
C:\Program Files\Common Files\Avid
C:\Program Files\Common Files\Digidesign
C:\Program Files\User\User Name\Documents\Pro Tools
I plan to copy those files back to these respective folders after I install 2021.6.
Have I missed anything?
(I want to be sure I have all of my plugins, plugin presets, and track presets. I regularly update the plugins I use a lot; trying to avoid reinstalling all of them).
I truly apologize for all the questions; it's been a while since I've had to do this and it's always daunting.
dg
Be Quiet Pure Base 600 case * Core i5-12600K * Gigabyte Z690 UD AX * 32 GB G.Skill Ripjaws DDR4 * 2X HP DreamColor Z24x G2 displays * NVIDIA GeForce GTX 960 * Samsung 980 boot drive * Samsung 870 EVO PT projects drive * Samsung 860 EVO PT archive drive * Novation Impulse 49 MIDI * PreSonus Studio 26c interface * PreSonus Bluetube V2 preamp * PreSonus HP4 headphone amp * JBL LR 305 monitors * Sennheiser HD 650 headphones *
Windows 10 Pro 64 21H2, Pro Tools 2022.7.0
Old 07-17-2021, 12:04 AM
Obsidian Dragon Obsidian Dragon is online now
Default Re: Clean install or update from 2020.3 to 2021.6?
I'm on a Mac but from what I've read, Protools 2021.6 for Windows 10 does require uninstalling the previous version. It should not require reinstalling plugins as it will rescan them upon startup and recognize them. Some older plugins may not be compatible and be placed into the unused folder.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 07-17-2021, 08:45 AM
dg27's Avatar
Thanks. As suspected.
I am still wondering about this part:
C:\User\User Name\Documents\Pro Tools [I had this path listed incorrectly aboove]
Old 07-17-2021, 10:47 AM
sw rec sw rec is offline
I don’t think you need to copy/reinstall those folders. Just uninstall the old version, install the new version. Somebody chime in if I’m mistaken.
Old 07-17-2021, 10:50 AM
The Weed's Avatar
The Weed The Weed is offline
When I update, I backup my Preferences with Trasher, uninstall Pro Tools from Programs & Features and choose to uninstall everything - at the bottom of dialogue window. I reboot, run CCleaner's Registry Editor until it runs clear and install the update, then reboot. If you don't have HD, then there is no need to install the HD driver, although it won't cause any issues if you do. I restore my Preferences with Trasher and start Pro Tools.
All my personal templates remain and are seen, all my extra Avid plug-ins and codecs, even Waves too, I don't need to move anything from/too or install anything but Pro Tools and whatever else the installer contains. Even my command switch for Processor Affinity still works with the new PT icon shortcut.
As an aside, I use CCLeaner to disable Avid Link at start-up and even that setting remains.
As always, YMMV.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 07-17-2021, 11:25 AM
Southsidemusic's Avatar
Is your PT plan and ilok license allowing you to update from 2020.3 to 2021.6 as that requires a paid plan or subscription. If you are on any plan I will ewcalate asap otherwise you keed to pay for that update.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 07-17-2021, 11:34 AM
dg27's Avatar
Thanks so much, The Weed. This very helpful.
Regarding this:
My understanding is that the "Pro Tools" folder located at C:\User\User Name\My Documents is created when Pro Tools is installed, and removed when Pro Tools is uninstalled.
So If I uninstall and reinstall as you've recommended, as an example, the Plug-in Settings subfolder in the PT 2021.6 version will only show the stock Avid presets, and not the presets the user has created. That's what I'm most worried about losing. My recollection is that those user presets must be saved to another location, then copied into the new installation's version.
I've attached an example of what I mean.
Is this not the case?
Old 07-17-2021, 11:43 AM
dg27's Avatar
The update to 2021.6 is clearly shown on the My Products tab in my Avid account, where it says this
Your Software Updates + Support Plan expires on May 13, 2022
All the files are available under my downloads (and I already downloaded everything).
I have annual subscription updates (a Perpetual Plan) until 2025.
In 2019 I bought four one-year renewals before the price went up.
I believe this means that I am good to go.
Please confirm--thanks.
Old 07-17-2021, 12:16 PM
Great! Just need to check as some people update by downloading althought they dont have a valid license plan but as per the PM you have.
I will escalate this and see what is wrong. Weekend at Avid HQ but hope an admin can jump in before monday.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 07-17-2021, 12:25 PM
dg27's Avatar
I'm not clear what you think is wrong or what needs to be escalated.
The update is shown under my available downloads and I already downloaded them.
I haven't uninstalled 2020.3 yet and was just waiting to install 2021.6 until I clarified a few things about the process.
Update:
Glad we resolved this via PM. You were just checking to confirm that I'm eligible for this upgrade, which I am.
Thanks for your help.
2021.6 install on the same drive as 2020.9.1 audioluche macOS 9 07-01-2021 07:50 PM
Pro Tools 2021.3.1 Update Won’t Install MrOZ Pro Tools 4 04-22-2021 07:51 AM
Anyone having issues with Security Update 2021-002 (Mojave) and PT 2020.12? Cacov Pro Tools 2020 3 02-28-2021 04:22 AM
Should the update from 11.2 to 11.2.1 be a clean install? writeroxie Pro Tools 11 2 08-15-2014 08:14 AM
Clean install, which update is best for XP cananball 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-31-2010 07:16 AM
