Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 07-01-2021, 03:38 PM
Goombot Goombot is offline
Default Spinning rainbow before offline bounce
I'm getting a spinning rainbow before offline bouncing. The bounce works but it doesn't matter if it's a big session or a tiny session I still get a rainbow before the bounce kicks in. Not sure if that has to do with the drive I'm working on or something else. Got it on two different versions of protools.
Old 07-01-2021, 09:51 PM
its2loud its2loud is offline
Default Re: Spinning rainbow before offline bounce
Any chance you have the SoundMiner plug-in on a track or any rewire type of plug-in?
Old 07-01-2021, 10:53 PM
I actually do. I’ll try taking it off and see what happens.
Old 07-02-2021, 01:48 PM
Cheesehead Cheesehead is offline
I've had this problem a couple of times.
Rewire definitely causes it.
Also a drive with messed up permissions on OSX caused it once too.
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12
Old 07-05-2021, 07:54 AM
Did removing that plug-in fix the issue?
Old 07-05-2021, 08:02 AM
Not totally. Once I removed the Rewire the rainbow disappeared but there was still a pause before the bounce started up. So not a big deal but it definitely did not work like that before.
Old 07-05-2021, 08:09 AM
There’ might be a short pause before a bounce depending on the session you’re bouncing. My larger sessions take more time to start and to actually process because there are more plugins, etc.
I still think the beach ball is caused by Rewire or Soundminer so at least that was resolved.
Old 07-05-2021, 08:49 AM
Yeah but this even happens on tiny sessions. I’ll have to dig a bit deeper. Honestly it doesn’t matter that much just curious really. Thanks for the tip.
Offline Bounce vs Realtime Bounce vs Recorded-in-Session - BIG differences in PT2021 andresix Pro Tools 13 11-19-2021 07:03 PM
Bug of the week: HDX offline bounce different from online bounce XJENSEN Pro Tools 2020 25 02-24-2021 10:17 PM
Offline bounce crash, probably Waves-related, and offline bounce not 100% correct Skwaidu Pro Tools HDX & HD Native Systems (Mac) 3 03-23-2015 03:55 PM
Offline bounce vs. Realtime bounce significant differences Mano Pro Tools 11 13 05-29-2014 05:58 PM
Pro Tools 8: bounce to disk spinning beach ball toddw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-14-2009 07:09 AM
