view Grid in MIDI editor?
I'm looking thru the manual and a v8 Visual Quick Start Guide that I just bought at the local store and I haven't been able to find out how to turn on the vertical grid lines in the MIDI editor. I have the grid set a 1/16th notes but have no vertical lines to help see the grid. I know it must be simple... just can't seem to figure out where the answer is. Can someone suggest where I should look for choosing to display the grid? Thanks and best regards, mike |
Re: view Grid in MIDI editor?
Next to where it displays the units of the grid, try clicking on the actual word grid (so it's black font on green instead of the other way around). This toggles the grid on and off.
If that's not it, then you may just be that you're zoomed too far out for it to display 16ths. |
Yes, that was easy. Thanks very much. I had clicked the drop down arrow next to it several times hoping perhaps I could find a choice in there, but did not know to simply "activate" the grid the way you described.
Thanks again and best regards, mike |
awesome! thank you! who knew? green and black!
The displays leave a lot to be desired, the main one being the BPM display on the transport, which is virtually unreadable unless it is DISengaged, oddly enough. This has been requested multiple times so hopefully it has been noted and eventually there will be a fix.
Midi Editor Scrolling View | goat1927 | Pro Tools M-Powered (Mac) | 2 | 09-20-2018 12:08 PM |
Midi editor grid gone | SqwEEk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-31-2012 02:09 PM |
Midi Editor notation view Track Order Bug | PTcomposer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-05-2010 10:52 AM |
View Midi Grid | bwandon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-28-2008 06:56 AM |
MIDI Grid View Problem | dburrows | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-24-2005 07:24 AM |
