Pro Tools Plug In Problems
So I bought a new MacBook pro a couple months back and a new MBox Pro. When I bought it I forgot to register it and didn't upgrade or even use the Pro Tools program til I upgraded to 7.4.2. Now that I have Pro Tools up and running I am trying to use Amplitube 2 as a plug in inside Pro Tools. Every time I start it up it gives out after a bit. First thing that happens is that the comp will run sluggish. Eventually a message will pop up saying I am running out of CPU power and then audio will drop out. Other times no message will appear and it will just drop out unexpectedly. I have the Hardware playback settings at Default mostly because I think my CPU should be able to handle them no problem on such a basic setup.
A couple things to note: 1. I am running plug ins wrapped as VSTs. (I tried the other way with the same results) 2. When I use Amplitube 2 as a stand alone it works flawlessly. 3. When I run Amplitube 2 I make sure I don't clip in the program. 4. I have the same results when I run Addictive drums (it just takes longer for audio to drop out) So my only common sense guess would be that it's not the plug-ins or Pro Tools itself but something with the computer. Is anybody having the same problems? Will I benefit from just re-installing my OS and starting fresh? I've tried optimizing my system but am a little unfamiliar with Mac Os's and what should be running and what I could do without under the Activity Monitor Window. Also note that I downloaded a program called IFree that is supposed to optimize the RAM space on your computer when run. (The problem started before). Sorry for the long winded letter but I thought it would help to be as specific as I can. I've posted various topics in other forums and so far no solution. If I don't get this fixed I'm going to have to resort to solely writing acoustic songs! __________________________________________________ _____________ MacBook Pro 17" 2.4 Ghz Intel Core 2 Duo 4GB 667 MHz DDR2 SDRAM Mac OS X Version 10.5.4 MBox Pro My Book External FireWire Drive Pro Tools LE 7.4.2 Amplitube 2 Addictive Drums |
Pro Tools 9 Plug In Clipping problems | Avocado Baby | Pro Tools 9 | 2 | 04-06-2013 04:58 PM |
Problems with Plug-Ins loading in Pro Tools | Chopper | Pro Tools 9 | 8 | 09-09-2011 05:34 PM |
Pro Tools 8 Plug-in/Upgrade Problems | dreambig207 | Pro Tools SE and Essential (Mac) | 2 | 08-27-2010 04:06 PM |
Pro tools LE factory plug in problems | jacofox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 04-29-2010 09:40 AM |
Plug In Problems in Pro Tools 7, anyone? | MichaelAS | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 01-16-2006 06:22 PM |
