Old 10-15-2013, 06:14 AM
tizi66 tizi66 is offline
Default EUCONTROL 3.0.1 Crash continuously on 10.8.4 & 5
Hallo i'm running osx 10.8.4 and from yesterday 10.8.5 just for see if the huge amount of problems disappear.
I have Euphonix MC Control and MC Mix, connected at Ethernet 1 thru Netgear Fast Eth Switch.
I'm running Logic X and Protools
In the past i had a stable system on 10.6.8 running Logic 9 and my Euphonix surface, but i need to move on Logic X.
I try to install Eucontrol 2.7 - 3.0 and 3.0.1 and Eucontrol always crash..
I clean the pref Manually and with the script in Library
I try with DHCP and with Manual IP (192.168.0.1/2 - 255.255.0.0)
I try to put the Euphonix order of network service on top in the Net Pref
My network Preferences always stay on "connected"
When i try to close Eucontrol it always need to force quit.
My surface is add in Eucontrol and the workstation is attached
My Mc Control always display AVID
Simply seems Eucontrol don't respond when i try to remove surface or see if the firmware is updated.
I'm a little tired...!
Thank you for your help
Old 01-03-2014, 03:40 AM
audiotator audiotator is offline
Default Re: EUCONTROL 3.0.1 Crash continuously on 10.8.4 & 5
Hello every body happy new year !
and sorry for my bad english !
i have exactly the same problem than you, but only with eucontrol 3.1 and I did the same thing as you to repair it, preference, user, library... uninstal and re-instal firmware P Ram etc…
but it' work better since i put the logic x control surface preference at the trash..
better but not normally…
my artist mix and control freeze… after a time…
everything worked very well with Logic 9 and 10 until I pass 3.1
[bleep]I hope that Avid will react even if it is not on protools or our equipment is brand Euphonix
[bleep]i'm sorry but it was so hard to have answers now !
please !
have a nice day
Old 01-03-2014, 05:25 AM
Here more details
, before trashing the logic x control surface preference (com.apple.logic.pro.cs) "EuControl" unfreeze whem quiting logic…
Now, no application appears as "not answering" in the "force applications to quit" windows, but the control surfaces freeze, even if we stop and restart EuCon in the system preference panes.
So the mix artist is reset, but not the artist control that display "preference system" instead of "Avid"
we must restart logic and appication EuCon surfaces for running again.
Firmware?? JC Haydon?
Thank you?
eucontrol crash Mexadon Artist Series 0 02-13-2013 01:21 PM
3 EUControl bugs + 1 crash bug OS X 10.6.4 Intel geoffb Artist Series 1 10-03-2011 02:21 AM
9.2 Crashes Continuously: 6 in one hour... [email protected] macOS 12 03-17-2011 01:53 PM
Continuously Crashing On Load BakedBeans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 12-08-2008 11:52 AM
Recording Continuously for The Ultimate Take www.mradlai.com 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-08-2007 11:07 AM
