Old 04-26-2021, 01:07 PM
dig1man dig1man is offline
Default Bus Leakage
he other day I created a thread in which mistakenly thought I had a bus I/O config issue. Actually this was a symptom of a larger issue that just popped up within the last few days.
I am having the exact same issue as described in the post below from 2011. I have reset my IO bus config numerous times. Actually also did a minor Pro Tools upgrade. I've tried creating new session using Pro Tools IO templates. At this point nothing seems to work.
https://duc.avid.com/showthread.php?t=298585
All I am basically doing is creating a Drum AUX Sub, along with a Compression and Reverb Sub. All of the Subs are sent to a final Sub Mix Master. I have inserts on individual drum tracks for Verb & Comp but when I pull down the Drum Sub fader signals from the drum tracks with inserts continue to the reverb and compression AUX channel then on to output.
Thanks in advance for any ideas.
Old 04-26-2021, 04:30 PM
Top Jimmy's Avatar
Default Re: Bus Leakage
Share your session so we can see your routing.
James Cadwallader
Old 04-27-2021, 07:41 AM
Sounds like some sends are in Pre-fade mode?
Tom mic leakage xterraguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 08-14-2009 10:07 PM
Pro Tools 8 info leakage... Dr. Marius Pro Tools TDM Systems (Mac) 48 10-03-2008 09:14 AM
Which headphones have the least leakage tracking? Chris Pro Tools TDM Systems (Mac) 18 03-12-2007 02:29 PM
kick drum leakage! help mr razor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 05-22-2006 12:49 PM
Leakage projectmusic Pro Tools TDM Systems (Mac) 1 10-01-2005 10:04 PM
