Can Digidelivery Serv LT be used with single static IP?
I'm thinking of getting a Digidelivery Serv LT so we can send files to people that haven't got a digi server. Does the Serv LT need its own external static IP, or can it be used on a network only having a single external static IP? At present I only have a single static IP from my ISP, with a router handling the internal IPs (either by DHCP or static internal in the 10.1.1.x range). If it can be used with a single external static IP how would I set it (or the router) so that packets can be sent to and from the Serv LT to external destinations via the Internet? Thanks, Phill. |
Re: Can Digidelivery Serv LT be used with single static IP?
This might better better asked in the Digidelivery-Forum but yes. The DD-server needs it´s own external static address so the clients can reach it.
frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
You can use it on a network with a single static IP but you'll have problems if you're running an externally accessible local HTTP server for a start (or any other externally accessible server that uses any of the following ports). If your external connection is only used for accessing external http/https/ftp etc services you're fine.
From Digi docs: Quote:
Firstly those ports will need to be non-blocked by your ISP. Secondly your router will need to be set to port forward those ports from your external IP address to the local network static IP you've set for the Digidelivery. Also, the Digidelivery can send notification emails directly or via an external email server, I'd recommend the latter. Pete |
Thanks, Phill. |
With ftp I then have to redirect port 21 to the IP address of the local computer with the ftp server on it. Do I have to do anything similar with Digidelivery as otherwise I'm not sure how external trafic will get routed to the Digi server? Incidentally, how are things? It's Phill at Universal Sound (foley) by the way. Cheers, Phill. |
Cheers, Phill. |
It's going well-ish, mad busy but schedules and rates... the usuals. Did Ben and Lee come up and see you a few weeks ago, I know they were planning to? I still haven't seen your 'new' set-up though I have heard it's fab and I know everyone's been very pleased with the results. You don't need to port-forward all the inbound ports I seem to remember - Boom bought my set-up when I left so I can't look at it right now. I'll check but if you're not using any of the inbound ones anyway you may as well do all of them. Inbound: 22/tcp 53/tcp 53/udp* 80/tcp 123/tcp 123/udp* 443/tcp All the best, Pete |
Thanks Pete, I appreciate all the help. Yes, Ben and Lee came over a while back, good to see them again as ever. Anytime you fancy lunch or a beer or two in Amersham give me a shout!
Cheers for now, Phill. |
Bought a ServLT but am now having problems with the initial setup. It connects to my network via Ethernet1 fine, and to a local PC via Ethernet2. However, when I try to enter the network information it restarts the services and comes up with network errors. I've checked that all the relevent ports are open on my router, and there is no firewall installed. I've also checked with my ISP and they don't block any of those ports. All the ports out seem fine, but none of the ports in seem to work. I'm not sure if its actually a port problem or if the DigiDeliveryTest.cgi file is actually missing somehow. I tried using a DMZ to the Serv LT IP but even with that it gave the same errors. I can't seem to get any further, as what ever I do it will not get further than this error. I've pased the error below so any thoughts would be really appreciated as I'm not sure what to try. Thanks, Phill. p.s. sorry to post this here but as I'd already started (erroneously) thought I might as well carry on this time! Network Tests Failed. There may be a problem with your network configuration. [ OK ] IP Address 10.1.1.50 [ OK ] Gateway address 10.1.1.1 [ OK ] The DNS Servers 212.23.6.100 212.23.3.100 appear to be working satisfactorily [ OK ] Port TCP/25 OUT is open [ OK ] Port TCP/80 OUT is open [ OK ] Port TCP/443 OUT is open [ OK ] Port UDP/123 OUT is open [WARNING] Port TCP/22 IN Not Found The requested URL /cgi-bin/digiDeliveryTest.cgi was not found on this server. [WARNING] Port TCP/443 IN Not Found The requested URL /cgi-bin/digiDeliveryTest.cgi was not found on this server. [FAILED ] Port TCP/80 IN Not Found The requested URL /cgi-bin/digiDeliveryTest.cgi was not found on this server. [FAILED ] Port TCP/80 IN Not Found The requested URL /cgi-bin/digiDeliveryTest.cgi was not found on this server. [FAILED ] Port TCP/80 IN Not Found The requested URL /cgi-bin/digiDeliveryTest.cgi was not found on this server. [FAILED ] Some Tests Failed |
FS: Digidelivery Serv|LT | KelB | Buy & Sell | 0 | 02-17-2014 12:18 PM |
FS: DigiDelivery Serv LT - offers invited! | SZE | Buy & Sell | 0 | 04-12-2013 11:08 AM |
DigiDelivery Serv|LT For Sale | MusicEngineer | Buy & Sell | 1 | 11-14-2012 07:45 AM |
Serv LT DNS | ddura666 | Aspera DigiDelivery | 5 | 06-18-2010 11:55 AM |
Digidelivery Serv|LT | Table Syrup Records | Aspera DigiDelivery | 2 | 03-27-2009 07:10 AM |
