Old 12-11-2002, 11:07 AM
knewbee knewbee is offline
Default Best sounding multi-mic pre unit on a budget?
So, I'm wanting to expand my setup beyond my API lunchbox so I can track drums and/or bands. I'm on a serious budget. I'd like to get 8 channels of nice pre, perhaps with digital i/o, or I could go analog. Basically, I just want something that sounds good, without breaking the bank.
Thanks for you advice...!
Old 12-11-2002, 01:36 PM
Barnabas Barnabas is offline
Default Re: Best sounding multi-mic pre unit on a budget?
It's hard to get high quality at the same time as low price.
Check out www.barnabas.com/sound/ . I put a list together last year because I was doing the same search you were. I ended up with the PreSonus M80 preamp. It's a good unit for the price. Now I have two Digi PREs.
www.barnabas.com Barnabas MultiMedia
Old 12-11-2002, 03:52 PM
blairl blairl is offline
Try Sytek. They have a 4 channel unit
http://www.sytek-audio-systems.com/mpx4a.html
The price on their web page says $1,600, but I think it's outdated. He'll sell them for around $800 - $900. You can also find them on e-bay quite often.
Old 12-11-2002, 04:54 PM
What about the M80? Is that cool? Does it sound good? How do the other PreSonus digital pre's sound, especially the DigiMax LT?
If I throw caution to the wind I may get 8 channels of something like the PreSonus, then 2 channels of Vintech 1272 or something like that, to complement my API. But then my budget goes out the window. Seems to happen a lot...
Buddy of mine gets damn good drum sounds just using his Digi 001 and a Mackie 1202 with the new Mackie pre's...
Old 12-11-2002, 05:09 PM
A1's Avatar
A1 A1 is offline
It seems like your mind is setup on PreSonus pres (which I think are good for the price) but I don't think there is much difference between the ProSonus and the Mackie mixer pres.
I own both (for location recordings) and use the Mackie pres for the most part.
Hope this helps. [img]images/icons/smile.gif[/img]
Old 12-11-2002, 05:54 PM
TiPo TiPo is offline
Yes! The new Mackie VLZ PRO mixers have newly designed XDR (Extended Dynamic Range) Preamps! They are amazing!!
Just go to my site and hear it yourself!
TiPo
Pro-Tools 10.3.10 HD 2 Accel PCIe
OSX 10.10.3
Old 12-13-2002, 07:39 AM
tom_mac tom_mac is offline
OctoPre. Anyone??
Focusrite..
they can be pure .......I can be PAID..
Old 12-13-2002, 08:40 AM
Mark Haliday Mark Haliday is offline
I have Octopre for two weeks and am quite impressed by the preamp which is class A by the way. Which of course is fantastic at doing away with crossover distorsion, but also qualifies it as a very good toaster [img]images/icons/grin.gif[/img] since the heat dissipation is quite something !
But things are under control with a small internal ventilator which is reasonably quiet (once inside a rack it should not be heard)
I think however that space should be left above the unit...
The analog sound is super, super clean (no added "warmth" here), and wide ranging,(-1db 10hz to 200khz !) no ugly low freq rollofs or brittle highs like on some cheap units .
I have done drums with it and the sound is very open, with clean highs
I also have the AES/adat A/D board and the converters are again very precise in the highs (we can thank 96 khz capable A/Ds).
I compared the sound of the analog output of a given channel going through a apogee AD8000 A/D with the same signal out of the ADAT digital output connected to an adatbridge 24 and the AD8000 undoubtebly gave a "warmer" and more cosy feel to the sound. However the octopre AD board is far from ridiculous in this comparative test, surprisingly good and clean.
Finally, the limiter I consider useless (read a review somewhere that said the same) in a "normal" studio environment (where somebody is supposed to keep an eye on levels [img]images/icons/rolleyes.gif[/img] ) unless one likes pumping effects... But in hectic live situations, this might prove a godsend.
Finally I have been told that Octopre sounds better than Presonus, which would be logical seen the difference in generation, but I have not been able to hear it myself.
Of course, just an opinion... [img]images/icons/cool.gif[/img]
Old 12-14-2002, 10:40 PM
macjam macjam is offline
I own the M80 and prefer it to the onboard pres on the Control 24. Great preamp for the price.
Old 12-15-2002, 12:01 AM
JasonWorrel JasonWorrel is offline
The RNP x 4. Eight channels of excellent pre for $2000.
Lexicon PCM70 multi effect unit - only 1 hour left!!! Recallbeats Buy & Sell 0 08-26-2013 03:25 PM
Multi-channel vs Multi-mono plugs on 5.1 tracks geitz Pro Tools TDM Systems (Mac) 0 06-07-2007 02:54 PM
Best Sounding Budget Mixer? rockwithrespect 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-03-2004 05:22 AM
I Need Clarification. Difference between Multi Channel and Multi Mono Plugs citi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-13-2002 11:08 AM
Multi Mono vs Multi Channel Plugins...Just curious... Mr T 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-18-2002 09:46 PM
