Old 12-06-2021, 02:23 PM
fdelorme fdelorme is offline
Default Kicked out by PT2021.7
I am using PT 20201.7.0 with one instrument track featuring Omnisphere.
Without any heads up, PT regularly kicks me out. Very annoying.
My setup is MBP M1 Max + Monterey.
Thanks for your insight.
Francois
Old 12-06-2021, 02:43 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Kicked out by PT2021.7
That is unsupported, configuration, you need to update your PT.
Janne
Old 12-06-2021, 02:49 PM
Thanks. Where/how do I do that properly?
F.
Old 12-06-2021, 04:20 PM
1. Work out where to find supported configurations. You could Google for that and find.... https://avid.secure.force.com/pkb/ar...tibility-Chart
2. If there are compatible installers, download those from your "My Products" section of your Avid.com account.
3. Just run the installer. (you of course have your system backed up)
4. Double check the system is properly optimized--you should have already done this before. (see "help us help you" up the top of each DUC web page)
5. It's also up to you to work out what third party plugins you want to install are also compatible with both the OS and Pro Tools versions.
And especially because you are running on M1 you better pay careful attention. Be reading Avid's compatibility info on M1 (want to guess how you find that?). More detailed questions/known issues with Monterey/explanations about compatibility are likely already answered on DUC. So again, search using Google (not the near useless built in Forum search), maybe with a site: duc.avid.com qualifier.
Don't expect other users here to spoon feed you, you have decided to be on the bleeding edge of using a M1 system, In your looking at existing DUC posts you should find reports of others with Izotope issues on recent Pro Tools releases, as well as issues on Monterey, including memory leaks. I suspect it's likely you might upgrade Pro Tools and find you have an Izotope issue... if that happens you'll likely need to follow up with Izotope support.
And I suspect most folks here won't have much clue what you mean by "kick out". You mean Pro Tools crashes with no error dialog? If you need more help here in future after exhausting all the info already on DUC try to describe exactly what technically happens, and exactly what you see on the screen happen.
Old 12-08-2021, 06:59 AM
Thank you for all these infos. I guess I am in the group of the guinea pigs!
I would have expected that the PT software would have been at least "stable" with M1 + Monterey. I guess it's not.
PT crashes unexpectedly. I am using Omnisphere 2 within PT, so perhaps this is the culprit. I will touch base with Spectrasonics.
In the meantime, I will be extremely prudent.
Thanks again for having taken the time to provide me with all that context.
Francois
Old 12-08-2021, 09:07 AM
JFreak's Avatar
Monterey has serious memory leaks and none of the Intel running software are really "stable". So hopefully Avid gives Santa a christmas present to deliver and we would have 2021.12 released soon (they have released .12 every year since they begun calling versions year.month) and it would be a very big present if it was Apple Silicon native PT software.
Janne
Old 12-08-2021, 09:23 AM
JFreak's Avatar
Oh... they just released 2021.12 while I was typing. Though it appears there is no Monterey support and not Apple Silicon native either. Well, that is for next year then.
Janne
PT2021.10 Upgrade Hangs Mark Corben Pro Tools 53 11-10-2021 05:02 PM
PT2021 and VirtualVTR Pythagor Post - Surround - Video 3 10-22-2021 12:37 AM
8.0.4 Kicked me in nads and stole my lunch money... SWSPHX Pro Tools TDM Systems (Mac) 6 07-15-2010 03:31 PM
Dear Avid - your email marketing intern needs their ass kicked jeremyroberts Pro Tools TDM Systems (Mac) 8 05-28-2010 06:14 AM
Toast CD reader "kicked the !@#*? out of the DVD Rom drive" shaggy Pro Tools TDM Systems (Mac) 0 05-08-2000 12:01 AM
