Old 12-03-2021, 07:27 AM
Jcoop Jcoop is offline
Default Elastic Audio - Relative Pitch Shift of Multiple Clips with Different Pitches
Heyo,
Does anyone know if there's a way to select multiple clips that each have different elastic audio real-time pitch shift applied and then shift them all relative to their current 'pitch position?'
The scenario - I'm a television music editor. I've been working on a cue for a scene and to make the ending work nicely I've had to change a few things around, add some different stems, pitch this one up, that one down, etc... Anyway, I bring in a cue (set of stems) for the proceeding moment and that works well but the key isn't jiving with the previous cue. If I could pitch this new cue up or down I would, but just by nature of the instruments/sounds used it isn't responding well and its squirrelly after only 1 semitone shift. I need to shift the previous cue, but within that cue there are probably a dozen clips of varying pitch positions.
I've attached a screenshot of what I mean. When you have multiple clips in selection that have different elastic audio pitch positions, it'll have an * in the Pitch Shift field in Elastic Properties. There doesn't seem to be a way to move them all up or down in a relative position. If I try to drag it, or input a new pitch value it just resets them all to the new value.
File Type: jpg Screen Shot 2021-12-03 at 10.25.30 AM.jpg (60.7 KB, 0 views)
Old 12-03-2021, 11:48 AM
Default Re: Elastic Audio - Relative Pitch Shift of Multiple Clips with Different Pitches
If you commit the pitch changes, then consolidate the set of clips you wish to change, then re-enabling Elastic Pitch will allow you to change all by the same number of semi-tones. I am not aware of any other way to do it. Using Melodyne might give easier control and better-sounding results
Old 12-06-2021, 05:06 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Try clip group then EA pitch.
Not near a rig to try, so it may or may not work.
Old 12-07-2021, 06:22 AM
True, but I would rather not commit the pitch changes until the music has been approved by the client. Also, not sure if you've ever tried pitch shifting a pitch shifted piece of audio, but it doesn't generally respond well :)
Old 12-07-2021, 06:23 AM
Unfortunately, you cannot group clips on Elastic-Audio enabled tracks.
Old 12-07-2021, 09:10 AM
I agree, which is why I do 98% of my pitch changes with Melodyne
Elastic Audio Pitch Shift Not Working Chris August Pro Tools 4 03-31-2021 03:02 PM
Can you automate the Elastic Audio Pitch shift on Audio tracks? DBK Getting Started 3 11-07-2014 03:38 PM
Elastic Properties Pitch Shift Value not Retained anklescrape Pro Tools 11 0 06-29-2013 10:04 PM
Pitch Shift VS. Elastic Pitch StinkyStan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-24-2009 09:15 AM
How Do I make Elastic Pitch shift gradually? products7074740 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-03-2009 03:43 AM
