Old 08-04-2021, 12:48 PM
Oscar Soto Oscar Soto is offline
Default PT 11 doesn't recognize mic 3 and 4 imputs Mbox Pro
Hi folks.
I have a Mbox Pro with PT11, and currently I need to record 4 channels simultaneously, but in menu selection imput I/O only recognize in1 and in2.
The interface has 4 mic channels in.
I check into audio device and there show only 2 mics in, so what can I do? I try download again the driver at AVID but it doesn't working.... So any suggestion?
iMac, Procesador 2.7, Intel Core i5, 2013
Memory 8 GB 1600Mhz DDR3
macOS High Sierra Ver. 10.13.6
Interfaz Mbox Pro
PT 11.3.1
Eleven Rack
Old 08-04-2021, 12:49 PM
Default Re: PT 11 doesn't recognize mic 3 and 4 imputs Mbox Pro
the SS
File Type: jpg Captura de pantalla 2021-08-04 a la(s) 13.31.16.jpg (49.6 KB, 0 views)
Old 08-04-2021, 04:19 PM
For me, the screen capture is too fuzzy to give any info. What about the IO setup page>Input tab? Open that and if it only shows mic 1&2, hit the default button and see if the rest of the inputs appear(if they don't, just click on "Add Path" and create 2 new mono inputs, Name them as you like and click dots on the grid to finish the routing).
Old 08-06-2021, 02:04 PM
I did it... but into Pt I/O Doesn't show channel 3 and 4 to choice the route only show 1 and 2 analog and 5-8 line analog
Old 08-06-2021, 05:13 PM
Top Jimmy's Avatar
The MBox Pro does not have 8 analog ins. It only has 6. I don’t know why the driver is laying out and labeling the paths the way it is but have you simply checked the ones labeled as “In 5-6” to see if Mics 3-4 were appearing there?
I suggest you delete all of the input paths and then click on the default button. Do the same for the outputs and buses.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Mojave 10.14.6.
Pro Tools Ultimate 2021.3, HD Native, Focusrite Red 8Pre (Mac)
Pro Tools 2020.12, Mbox3 (Win)
Windows doesn't recognize Mbox? Blackhawk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 05-13-2012 08:55 PM
Pro Tools Doesn't Recognize MBox 2 Pro RBM01991 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 09-24-2010 11:27 AM
PC doesn't recognize MBox 2 FJBrooks586 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 01-21-2010 04:30 PM
PT 7.3.1 doesn't recognize Mbox Mini in Mac OS 10.4.10 irongiant14 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-08-2008 01:36 PM
Computer doesn't recognize mbox matthewbillie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-16-2004 04:33 PM
