Old 01-29-2010, 11:39 AM
Floeperd Floeperd is offline
Default Midi help needed with digi002 no midi at all
Hello, i own a digidesign digi 002, with pro-tools LE
and a Akai MPK49 with usb connection, in Reason i can use my digi as a soundcard, and the mpk49 works perfectly, but in Pro tools, i can use all the cool Digi002 features, but i cant get midi to work, i've tried to connect my mpk49 directly in my digi with midicables, but with no result, and the lights of midi in en midi out on my dont even light up.....
does my digi needs repair??
or do i need a seperate power supply for my akai mpk49, since i use the usb for power.....
I tried all the settings, downloaded the cs10 update, read every topic on the net about it....
i cant figure it out, used every setting in pro tools possible....
can someone please help me???
Old 01-29-2010, 12:21 PM
DigiTechSupt's Avatar
Default Re: Midi help needed with digi002 no midi at all
Go to the Program Files>Digidesign>Pro Tools>Drivers and double-click on the MMERefresh app. Do the MIDI ports now show up in Pro Tools?
Avid Audio Tech Support
Support FAQ
Old 01-29-2010, 12:27 PM
i can see the ports in pro tools, thats not the problem, but when i select them in pro tools nothing happens, and the lights of midi in and midi out on my digi stay off,and i suppose they should light up when i plugged in midi, i read that i should light up everytime i do something on my keyboard, but that doesn't happen either...
but i will try the mmerefresh app....
Old 01-29-2010, 12:49 PM
didnt work....
please someone knows what i do wrong?
or is my digi f$@#ked?
Old 01-29-2010, 01:03 PM
to test, i've powered the mpk through another laptop, while having the midi in and out directly in my digi still no signal, no midi lights....
Old 01-29-2010, 09:51 PM
some help please????
Old 01-30-2010, 12:37 PM
i need to know if i need to have my digi002 repaired or not....
Old 01-31-2010, 07:38 AM
Helloooooooooooooooooooooooooooooooo?
Old 01-31-2010, 07:45 AM
You can use USB midi connection in pro tools. You do not have to use the midi ports on the 002. If you are connecting the mpk via midi cable to the 002 you HAVE to use the power supply for the mpk.Make sure your midi input is the correct device and typically selecting all channels is fine.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 01-31-2010, 08:26 AM
did all that, i gave up on the midicables, and back the usb port, i can select it in pro tools, but i cant seem to make it work...what do i overlook?
HELP needed with MIDI LiteraryLady Windows 2 12-18-2012 09:36 PM
Help Needed - Midi JackSummer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-04-2007 04:36 AM
USB Midi help needed ... Jonah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 06-19-2003 12:03 AM
Digi002 Midi uses the new Midi TimeStamping??? Targon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-08-2002 10:11 AM
MIDI HELP NEEDED laupflow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-17-2002 10:50 AM
