Old 08-10-2001, 12:03 AM
evanbrubaker evanbrubaker is offline
Default HELP! Jerky Meters, Counter, and Scrolling
Ok, I've searched the answerbase and tried all of the recommendations:
*Energy Saver Control Panel is On and set to never
*I've zeroed out the memory setting for DAE and PT
*Disk Cache is set to 512k.
The jerkiness remains but ONLY ON CERTAIN SESSIONS! It has nothing to do with how many tracks are being used or plug ins or anything but some sessions play back jerky every time and others not.
OS 9.1
PT 5.01
G4 Yikes
MixPlus
Any ideas are much appreciated.
Thanks!
evan
Old 08-10-2001, 06:01 AM
DigiTechSupt's Avatar
Default Re: HELP! Jerky Meters, Counter, and Scrolling
-Are the "normal" and "jerky" sessions all playing back from the same drive?
-If possible, copy the sesssions to another drive and see what type of performance you get.
-Track Transfer one of the problematic sessions into a new session file and see how it performs.
Brent
Avid Audio Tech Support
Support FAQ
Old 08-10-2001, 06:35 AM
Mt.Everest Mt.Everest is offline
I experience the same symptoms but I finally figured out what was causing it for me. Whenever I have OMS Application loaded at the same time as PT this happens. After I quit OMS, the session goes back to normal.
Probly not the case with you, but i thought id put it out there...
MT
PT|HD4 Accel PCIx w Magma Chassis & 192 I/O
PT HD 9.0.5 - Mac Pro 8-Core 2.4Ghz Westmere 10.6.8
PT|HD 9.0.5 - MacMini Core-Duo, 10.6.8 - ProFire 2626
•••DON'T BELIEVE THE HYPE•••
•Use & Trust ø Cancellation!•
Old 08-10-2001, 07:39 AM
Thanks for the suggestions!
Brent: I have tried playing the files back from different drives and I get the same problem. I have also tried Saving Copies with all the audio files and the problem remains. I will try doing a track transfer and see if that helps. I wonder if the sessions files got corrupted somehow. I dunno.
I am hoping that creating new sessions and importing all of the tracks will help but I'm try to save that as a last resort so I don't have to consolidate all of my edits.
Old 08-10-2001, 09:17 AM
mixermon mixermon is offline
I have had this problem before as well. When it happens to me I change my zoom setting i.e. zoom out and then zoom back in. The problem then goes away. Could this be a video card memory issue?
Old 08-10-2001, 09:28 AM
NinjaBob NinjaBob is offline
Evan - Your movie window is probably trying to play on a monitor that is hooked up to something other than your video capture card. Try this:
Guessing that your have a Jeronimo2000 AGP dual monitor card, "Show" your Movie Window. If it comes up on a monitor that is hooked to the J2K, move it to a monitor that is not hooked up to that card. If this is not an option, take the movie offline and close the Movie Window. If the Movie Online option is greyed out, you'll have to create a video track, import a quicktime movie (doesn'y matter what), take the movie offline, and clear the video track. Hope this helps.
Ninja Bob
Hothead
NYC
Old 08-10-2001, 02:57 PM
Jan Folkson Jan Folkson is offline
Hey Evan,
I've experienced this as well. The cause of my problems was the Direct Connect plug-in. I was using the NI B4 plug with DC and all was well, I then tracked all my midi stuff to audio and muted the midi tracks and hid them. However, opening up the same session later that day it was very jerky, just like what you're experiencing. Turns out that as soon as I opened the B4 software all was again well. So having a DC plug active in a session without having the corresponding app opened will cause the problems you're having.
It's probably unrelated, but I figured I'd post it.
Good luck.
- Jan
- Jan Folkson
www.janfolkson.com
Old 08-10-2001, 03:51 PM
Jan-
That was totally it!
DirectConnect was trying to connect with the B4. Sessions have returned to normal.
Whew!
Thanks to everyone for their help in tracking this down!
Best,
Evan
jerky stuttering meters and tc display agus ProControl, Control|24, Command|8 2 07-21-2006 02:53 PM
AMDX2 Jerky meter and counter behaviour solved! Dr Dave Pro Tools M-Powered (Win) 3 02-19-2006 04:37 PM
meters/counter hesitation Bluesdude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 06-17-2002 03:37 AM
Counter & meters freeze for a while? Alex TCH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-15-2002 07:32 AM
"jerky" scrolling and numbers nz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-11-2000 02:01 PM
