Old 12-23-2000, 01:41 PM
dw dw is offline
Default will the VST USB floppy works ???
i just upgraded to the G4 and my dealer does not have any Imation super disk left so i wanted to know if the VST usb floppy drive will work....What a LAIN in the butt this is !!
Thanks
Old 12-24-2000, 08:09 AM
snoopy snoopy is offline
Default Re: will the VST USB floppy works ???
Yes. Download the USB Floppy enabler software to allow PACE to work or else you'll freeze up while running the authorization programs.
Colin Miller
Teaboy Audio Recall Sheets
http://teaboyaudio.com
Old 12-24-2000, 09:47 AM
dw dw is offline
snoopy,
Are you sure ?? i have the USB floppy enabler in the extension and it does not work at all. Actually when the Pace Floppy enabler is present the VST usb disk drive does not see any disk inserted in it. Without the Foppy enabler, at least, the VST disk drive recognize when you have a disk inserted BUT, it 's sort of useless because without the Floppy extension, you cannot authorise....HELP
Old 12-25-2000, 11:35 AM
AnthonyBK AnthonyBK is offline
I've managed to get a Teac USB drive to work, which is unsupported by Pace. DO NOT use the Pace floppy enabler, DO NOT use the floppy enabler on the Protools disk. I installed OS 9.0.4, then downloaded the Teac floppy enabler, installed them (against their instructions for OS 9) and everything worked. YMMV. A similar process may work for the VST floppy
Anthony B. Kitson BSEE
Pinnacle Recording Studio
http://www.pinnaclestudio.com
Old 12-25-2000, 05:59 PM
onemanband onemanband is offline
Haven't dealt with this in about 8 months but I think Anthony's right. Best bet is to go To VST site and see what they have and ask them how to handle. If I remember correctly there were some VST floppies that would work with PACE and some that would not. You need either the model # or the serial # to determine if your floppy will work. I bought my floppy first which was a mistake because it was one of the models that was not supported. Also check the PACE site - I think that Newer technologies had a PACE compatible floppy, and like I said, my information is old so hopefully there are others which are compatible by now.
Good Luck
Bob
Old 12-25-2000, 09:53 PM
Gulliver Gulliver is offline
Floppy technology is dead. Put your money into a CD-RW. With 600MB, why are you waisting your time even thinking about floppy? Also, you need a burner to mix down to anyway.
Old 12-28-2000, 07:21 AM
DigiTechSupt's Avatar
In addition to the Imation SuperDisk, the Newer Tech U-Drive also supports PACE copy protection.
Brent
Avid Audio Tech Support
Support FAQ
Old 12-28-2000, 08:07 AM
MichaelEarthMedia MichaelEarthMedia is offline
Unfortunatly some Digi products require a floppy drive to get Authorization codes.
I cannot get my Teac USB to work on authorizations at all. Sorry I am no help!
Regards Michael
Old 12-28-2000, 10:24 AM
tech_head tech_head is offline
I recently purchased a Newertech uDrive from Outpost.com. It works fine with the Pace enabler on a Dual Processor G4. I went for the uDrive since Digi had it on the approved list and so did Pace.
Outpost had it overnight with free shipping.
tech
Old 05-19-2001, 05:32 PM
tomhartman tomhartman is offline
I'm having a nightmare trying to install AMP FARM, and it must be the USB Floppy Drive I just got from Sweetwater. It's the VST, and as a poster already pointed out, you can't use the PACE Floppy extension, because it conflicts with the extension that comes with the VST. What a mess. Buy software, can't use it.
Any ideas???
Mbox 2, Input works, sound for non-protools works... rmiller9969 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-13-2011 04:13 PM
It Works! My Protools system works!!! Woooooo Hooooo!! Siberian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 03-19-2003 08:48 AM
USB Floppy madness markjohn Pro Tools TDM Systems (Mac) 9 05-03-2002 08:22 PM
vst usb floppy chilli Pro Tools TDM Systems (Mac) 2 12-06-2001 10:26 AM
USB FLOPPY SPIDEE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-01-1999 07:32 AM
