Old 10-02-2005, 08:43 AM
MaLa MaLa is offline
Default Recording 2 mono tracks to a mono track
I've tried to do this. But wasn't able to do it.
I have 2 mono tracks with plugins and I want to record those 2 mono tracks into one new mono track in Protools.
How do I have to set everything to make it work?
Mbox ProTools LE 7.0
Show a little patience! I'm female & blonde
Old 10-02-2005, 09:01 AM
lemix's Avatar
lemix lemix is offline
Default Re: Recording 2 mono tracks to a mono track
MaLa,
Solo them, both panned to one single bus, and "bounce to disk" from that single bus to a new mono destination track. Don't change properties, and "import back to session"
good luck,
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 10-02-2005, 09:12 AM
The fast Digi board. Thanks.
I just found the wrong setting and I used bus mono 5 for both mono tracks and input bus 5 on the new mono track and it worked. Is the bounce way better?
Thanks
Old 10-02-2005, 09:46 AM
lemix's Avatar
No, it's not. It was just faster to explain
cheers,
cheers,
Andrew
Old 10-02-2005, 11:01 AM
cheers,
Thanks anyway!
making mono track into stereo or double mono in PT7LE VeganMuso 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-02-2012 06:36 AM
A question about mono/stereo plug ins on mono tracks. rockguitarist1255 Pro Tools 10 2 12-24-2011 08:33 PM
one mono audio file when two mono tracks recorded bluerej Pro Tools M-Powered (Win) 0 02-06-2010 02:09 AM
one mono audio file when two mono tracks bluerej Pro Tools M-Powered (Win) 0 02-06-2010 02:06 AM
Mad tracks! Should I track in stereo? Mono? epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 11-05-2003 10:52 AM
