Old 12-03-2021, 07:29 AM
CHD CHD is offline
Default SRC not working on "Import Audio" PT 2021.3.1 Ultimate
I am experiencing the issue with SRC not working on "Import Audio". No matter what source sample rate I specify the files are imported at their original sample rate, so no speed changes are available (I've been using this feature for speeding up/slowing down audio for almost 20 years). I tried every combination of settings in Preferences with no results. MacBook Pro M1 13" 16GB, MacOS 11.6.1 clean install, PT Ultimate 2021.3.1. I found a dedicated thread for this bug here
https://duc.avid.com/showthread.php?t=415522
but I wonder is it only me and only one other person who experience this bug? I find this variable sample rate SRC function essential for many Post workflows.
Dmitri A. Chernov
re-recording mixer/supervising sound editor/studio owner
Moscow, Russia
http://www.imdb.com/name/nm2555539/
Old 12-03-2021, 07:38 AM
michaelfbates michaelfbates is offline
Default Re: SRC not working on "Import Audio" PT 2021.3.1 Ultimate
I also had this problem recently on PT Ultimate 2021.3.0, I'm running OS 10.15.7 on a 2019 Mac Pro.
I found that doing Import Session Data and making the SRC there worked as SRC on Import Audio did on previous versions.
PT Ultimate 2021.3 | macOS 10.15.7 | Mac Pro 7,1
michaelfbates.com
imdb.com/name/nm4876413
Old 12-03-2021, 09:01 PM
smurfyou smurfyou is online now
Hi Dmitri, just did a quick test and it seems to be working here on 2021.7
MacOS 10.15.7
~Will
Old 12-04-2021, 12:29 AM
CHD CHD is offline
MacOS 10.15.7
Thank you Will! Nice to know that they fixed it in 2021.7. I had stuttering GUI in 2021.6 and per the advice of others experiencing similar problems with M1 Macs rolled back to 2021.3.1. Haven't tried 2021.7 because I read that this stuttering issue is still there. Looks like I need to try 2021.10.
Dmitri A. Chernov
Moscow, Russia
Old 12-04-2021, 11:42 AM
I'm on a 2018 Mac Mini i7 FWIW. Haven't updated to 2021.10, too busy to test it out.
~Will
Old 12-05-2021, 04:39 AM
garret garret is offline
Hi Dimitri
Yes I noticed this as well. It works if you import tracks and do the sample rate conversion and also if you use the custom option and manually enter the sample rate.
IMDB
Old 12-10-2021, 03:14 AM
CHD CHD is offline
Installed 2021.12. The Import Audio SRC works now! No GUI stutter encountered yet as well. Looks like a nice release.
Dmitri A. Chernov
Moscow, Russia
HTML code is On
"cannot communicate with audio interface" errors with PT 2021.10 eightamrock Pro Tools | Carbon 16 12-09-2021 07:50 AM
Pro Tools Ultimate 2021.6 Import Audio problem drumfarmer Pro Tools 2 07-20-2021 02:23 PM
Import Audio crashes PT Ultimate 2021.x Metalgez Pro Tools 11 07-03-2021 12:42 AM
Does "Automatically Copy Files on Import" work with Import Audio command? leftalive Pro Tools 10 3 04-17-2013 09:35 PM
