Old 04-11-2015, 03:43 PM
mesaone mesaone is offline
Default iZotope Insight loudness history graph not working? Fix inside.
I noticed the loudness history graph did not function in some iZotope Insight presets. Both AAX and VST versions were affected. Re-installing did not fix it. There's no setting inside the plug-in that would influence this behavior. Not any setting that you can reach from the GUI, anyway. I figured out a fix...
1. Navigate to where your computer stores iZotope Insight presets. If you don't know where this is, just open up the preset window in the plug-in and click "Change Folder". It will reveal the current preset directory. Close and deactivate the plug-in, then use the finder or windows explorer to open the preset directory.
2. Back up the folder just in case. I usually just create a zip file in the same directory.
3. Open the offending presets with a text or XML editor. I use Notepad++.
4. Remove any lines in the preset that include LoudnessHistory Magnitude Range. You should only have to do this once. This doesn't affect the behavior, it just "resets" the loudness history.
For example:
Code:
Param ElementID="State" ParamID="LoudnessHistory Magnitude Range Maximum" Value="-0.23358744"
Param ElementID="State" ParamID="LoudnessHistory Magnitude Range Minimum" Value="-17.27415276"
5. And finally, save the preset without changing the file extension.
Now the loudness history graph should function properly in your presets, and the other settings remain unchanged.
For reference, the following presets were affected on my machine.
  • Frequency and Loudness Scroll
  • Headroom Warning
  • Loudness Tracking
  • Podcast Production
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
HTML code is On
FS: Protools 8 HD also Izotope Insight TVPostSound Buy & Sell 3 04-19-2016 09:06 AM
iZotope Insight crashing PT10 noiseboyuk Post - Surround - Video 5 06-16-2015 11:46 AM
Izotope Insight Meters SomeDumbHuman AAX Plug-ins 4 04-25-2014 11:55 AM
Izotope Insight RecRoom Post - Surround - Video 27 12-13-2013 04:14 AM
