Old 02-03-2012, 09:27 PM
txshonk txshonk is offline
Default Midi File wont import
I am working on attempting to convert several older projects into PT. I have midi files that I am able to imprt into SawStudio and Reaper - but when I try to imprt them into PT I get nothing - Its like PT doesnt see any midi data in the file.
I have used the same process to export the midi data from the projects and some files imprt into PT and others dont.
Any ideas?
Dave
Old 02-04-2012, 12:22 AM
Default Re: Midi File wont import
Clip Bin?
Aaron Mulqueen - 001 HD Native
Old 02-04-2012, 05:23 AM
Originally Posted by filosofem View Post
Clip Bin?
Nope - I have tried new track and new clip when importing and either certain midi files (exported the same exact way as others) wont import.
The only way I can come up with is to loop the midi signal out of another DAW and into PT.
Which is not a very elegant solution at all.
Old 02-04-2012, 01:55 PM
Where had the MIDI files originate?
Old 02-05-2012, 07:47 PM
The clips were created in Reaper. Most of the ones I export from Reaper import into PT no problem. Others have issues. I also tried importing the midi clips intoo SawStudio and then out to midi again. But that still didnt work.
I am guessing there is some setting missing that makes it fail when importing into PT so that PT doesnt see the midi data.
Old 02-05-2012, 09:21 PM
What options does Reaper MIDI Export offer?
Old 02-07-2012, 06:37 AM
I was going to post a screen shot of the export options and also a midi file that wont import, but it doesnt look like there are attachemnt options on the DUC?
Old 02-08-2012, 06:35 PM
Use Photobucket.
PT's Bar#1 and midi file import D Bag Pro Tools TDM Systems (Mac) 3 08-16-2009 03:20 PM
Import Midi File NOT WORKING !!!! dogeatdogg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-04-2009 10:51 AM
How to import a Gen.Midi file into PT? fingerz88d MIDI 3 03-12-2003 06:34 PM
Midi-file import problem Rameshgar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-08-2000 08:20 AM
Midi file Import. Sutee Sangsareechon Pro Tools TDM Systems (Mac) 0 11-30-1999 08:20 AM
