Old 04-01-2011, 07:40 PM
weedrock weedrock is offline
Unhappy Protools cannot initialize current playback device......HELP!!!!!
Hey anyone out there-
I installed PT 9.0.2 From 8 blah blah blah and it boots but when it gets to the DAE initialize it gives me "Protools cannot initialize the current playback device. Please make sure the device is configured correctly"......WHAT THE HELL DOES THIS MEAN? And then I hit OK and it closes.
I'm trying to boot it without an interface and use my Macbook Pro speakers for playback. Nothing too difficult, right?
Any help is appreciated. I've uninstalled twice and reinstalled. No luck. Thank god I bought Record at the same time so I can still work. Ok enough bitching.....
Weedrock
Old 04-01-2011, 11:57 PM
slater05 slater05 is offline
Default Re: Protools cannot initialize current playback device......HELP!!!!!
I had this problem a few months ago when I first got 9.
So the way PT9 works is that it always wants to open up with the hardware configuration that it previously had opened. For example, if I had Pro Tools previously opened with my mbox hooked up, it expected that it would be the same the next time.
The work around is to hold the 'n' key while the startup window is loading, and then it will open the playback engine window, you can change PT to whatever setup you wish to be using, and you're off to the races.
www.mikeslatermusic.com
PTHD9 Certified Operator
15" MBP 10.7.2
Pro Tools 10.0
Apogee Duet
M-Audio BX5A's
Old 09-28-2011, 02:23 AM
brewj brewj is offline
Noce one thank you for this you saved my bacon at the Royal Albert Hall today for a show of Phantom of the Opera.
Old 11-01-2011, 08:47 AM
kBiz kBiz is offline
Wow - thank you for this! I still don't understand why they don't add instructions like this to the error message. "Pro Tools could not initialize current playback device. Restart Pro Tools while holding the 'n' key to change playback settings. You're welcome."
HD11.3, HD I/O, SyncHD, MacPro 2x2.93 Quad 32GB, MC Mix & Control, BlueSky ProDesk5.1
Pro Tools could not initialize the current playback device (on 10.2.0) Cosme macOS 1 07-18-2012 07:45 PM
Fix #1 for "Protools could not initialize the current playback device" jamesb1t macOS 1 06-13-2012 11:21 AM
"Protools could not initialize the current playback device" textiles Pro Tools 9 8 05-08-2012 10:33 AM
Pro Tools could not initialize the current playback device mkpascucci macOS 4 05-01-2012 05:00 PM
Pro Tools could not initialize the current playback device johnwesleybarker macOS 2 01-14-2011 06:52 PM
