Old 11-30-2010, 12:57 AM
martinxkirby martinxkirby is offline
Smile How to set up RME Fireface and Pro Tools 9
Hi im just trying to set up my RME Fireface 800 with PT9.
I have a RME Octamic connected to the Fireface 800 through the analog inputs so 10 inputs in total... Not using the ADAT.
In the hardware tab I can only get 'Generic Low Latency ASIO'... and when I launch setup app I can see fireface inputs and outputs but I want to be able to enable all 10 inputs that I have!
Is Generic Low Latency ASIO the only option for anyone not using PT hardware or should I be trying to get RME Fireface 800 to appear in the Peripherals options as it is in Cubase?
Safe to assume, and after searching I don't think RME have released any support for setting up their hardware with Pro Tools 9 yet.
Thanks for your help in advance!
MK
Old 12-01-2010, 01:29 AM
Default Re: How to set up RME Fireface and Pro Tools 9
Anyone?
Old 12-01-2010, 02:24 PM
geetarpicker geetarpicker is offline
Seems something is not installed correctly.
I have an RME FF800, and currently in the RME panel I have the "bandwidth" backed off one notch so it's showing "An./SPDIF/ADAT1", as I basically have the ADAT2 inputs turned off. Then in PT9 it's showing under hardware setup as one entry "ASIO Fireface". One oddity on that panel is clicking on Launch setup app doesn't do anything, however I just close PT and go to the RME settings panel to set it up. In PT9 I/O all the inputs/outputs of the FF800 should show up, and with my bandwidth cranked back one notch I still have a total of 20 ins/outs in PT9. You mentioned only seeing "Generic Low Latency ASIO", but I see "ASIO Fireface" so it appears your PT9 install isn't finding your RME driver but something else...
Perhaps you need to reinstall your FF800 drivers, then find the RME Fireface mixer panel and Fireface settings panel. I'm finding everything from my RME FF800 is posting in Reaper, Sonar, and PT9.
Hope that helps!
Old 12-01-2010, 03:21 PM
Cool, thanks for your help / confirming there should be the RME Fireface driver option. Definitely helped but I bet it will drive me insane trying to work out why its not recognizing it, although is working fine in Cubase etc.
Weird though, I just installed the latest RME drivers and, on my third attempt PT9 actually installed properly... the first two had a hiccup or crashed.
Old 12-04-2010, 05:05 AM
Still struggling with this...
PT9 just won't find the Fireface ASIO drivers.
Have installed latest Fireface drivers.
Cubase recognizes it, Windows Media Player etc...
Anyone else?
Old 12-04-2010, 05:10 AM
Just worked it out... had to go into Playback Engine and Fireface ASIO was just chilling there... ridiculous I had clicked every other menu possible except for that one, just didn't click for me.
Hopefully this helps anyone else!
Old 10-20-2011, 02:14 PM
mrflat mrflat is offline
i guys
why pt9 didn't play sound on my second fireface 800.?
i work with pt9,2 fireface 800 and DM2000.in pt i/o setup i can see all the default in and out for both fireface,if i play i can ear sound only from the track 1 to track 16,but no sound from 17 to 32...but in pt ther are signal presence...
help me please
[IMG] code is Off
Fireface UFX/Pro Tools 10 raggin macOS 3 05-02-2012 09:52 AM
Fireface Optical Set Up In Pro Tools batistamusic Pro Tools 9 0 10-30-2011 10:13 AM
Pro Tools 9, Adat and RME Fireface variantboy macOS 1 04-10-2011 02:05 PM
RME Fireface 800 and Pro Tools 9 Sessdrum Pro Tools 9 0 12-11-2010 06:35 PM
Pro Tools 9 and my FireFace UC ..... ? ben ifin Pro Tools 9 3 11-06-2010 06:56 PM
