Old 02-25-2009, 09:45 PM
Blank Frank Blank Frank is offline
Default Looping samples in Structure LE.
Does anyone know how, or if it's possible, to get samples to loop in Structure LE. For instance if I have a 1 bar drum loop that I want to play for as long as I hold down the key, is there a way of doing that?
Thanks
Old 02-26-2009, 01:39 AM
flommer flommer is offline
Default Re: Looping samples in Structure LE.
Yes you can do this..
I have been playing around with it a bit, but I'm having a couple problems that I hope others will be able to clarify..
I have a patch created with 3 different drum loops dragged in as parts..
I realize how to change the key-range of an individual part to just a single note/key, but the loop is then playing based on the pitch of the note. I can then transpose the part by whatever it takes to get it back to the correct tempo/pitch. But I suspect there must be an easier way. I can't seem to find a way to turn off "note tracking" or whatever this function would be called.
Using sub patches seems to offer some more control, so maybe there are some tricks to that..?
I also am intrigued by the functions available under Add Part>MIDI>...
But there is almost nothing in the plug-in guide about that stuff. Is there any other source for info on some of this detailed stuff? Maybe the full version of Structure has better documentation? I realize that Digi would probably like me to buy the full version if I'm interested in detailed Patch editing, but thats not gonna happen right now...
TIA
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Structure 1.1 looping/x-fades jdk11211 Virtual Instruments 0 09-09-2010 06:54 PM
Looping samples click in between / aren't in time joshsvoss 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-07-2010 05:51 PM
looping sounds in structure fender747 Virtual Instruments 4 04-14-2009 04:11 PM
Looping Samples in Structure Free dsteinwedel Virtual Instruments 0 01-14-2009 05:32 PM
Basic Structure Looping Help. jimmyz Virtual Instruments 2 12-10-2007 05:33 PM
