Old 12-03-2005, 07:58 PM
SBishop SBishop is offline
Default midi timing issue in 6.8 and 7
I've had this problem since the initial release of m-powered and was never able to find a solution. I had hoped version 7 would alleviate my troubles but unfortunatly it has not so I will post again hoping someone else has expirienced this and knows what's going on.
For some reason, any midi being sent to any destination, either a softsynth or hardware through the audiophile 2496 midi out plays back with extremely inconsistant timing. I've adjusted the buffer size and the DAE playback engine level up and down, back and forth and it has no effect on this.
hardware:
ASUS P5T-533 C MoBo
P4 2.4 Ghz non HT
1 Gig PC1066 RDRAM
2x40 Gig HD's
Delta Audiophile 2496
I've been trying to migrate to Pro Tools as my main DAW since the relase of M-Powered, but since I do a large amount of MIDI programming, this has been impossible.
MIDI timing issue Reynard Foxe Pro Tools 10 0 11-21-2012 05:03 PM
Sync issue, pro tools MIDI and MIDI controller, timing issue Angelo of Onello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-29-2011 08:57 AM
MIDI timing issue PT9? antidogmatiq Pro Tools 9 3 04-22-2011 10:16 AM
midi timing issue corp MIDI 1 04-06-2011 11:39 AM
MIDI timing issue with 7.3? Rammelt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-12-2006 01:58 AM
