Old 03-15-2012, 12:16 PM
krazylain's Avatar
krazylain krazylain is offline
Default Lock Avid Mix to Pro Tools 10 (Windows 7 64)
I had inconsistent connection problems that everyone complains about on this forum.
I resolved those problems by using a switch on Ethernet port#1 for my two Mixes and by turning off windows firewall while using ProTools 10.
If i use only protools, the mixes remain connected for hours. If i use another app, they disconnect and i have to uncheck/check Eucon control in the peripherals menu to reconnect.
How do you lock Avid Mixes to only control Protools?
Studio: iMac Pro 8core 32GB | Pro Tools Ultimate, Studio One 5 | Apollo X16
Analog EQs and Compressors (SSL, Neve, Trident, Dione, Successor..)
VIs: Arturia, NI Komplete, IK, Omnisphere, UVI
Plugins: McDSP, Sonnox, Waves, Brainworx, IK, UAD
Instagram
YouTube
Old 03-15-2012, 04:41 PM
Brandonx1 Brandonx1 is offline
Default Re: Lock Avid Mix to Pro Tools 10 (Windows 7 64)
You can lock the mix to pro tools in the eucon app. I think it's under the assign tab but I'm not sure (I'm not in front of my DAW currently).
Old 03-15-2012, 06:43 PM
krazylain's Avatar
you are correct. It's on the Assign tab.
I tried that before, but it did not work.
Strangely or luckily enough, it worked tonight.
I was able to lock both avid mixes to ProTools.
After my initial problems, it looks like the best way to run Avid Artist series is to disable firewall & Internet connections.
thanks again.
Instagram
YouTube
Pro Tools will not Install - How do You Download Windows XP Updates from Avid Dave12 Pro Tools 10 6 01-03-2013 11:07 PM
What License Do I need to lock Avid MC5 with Pro Tools using Ethernet kd_special Post - Surround - Video 9 02-16-2011 08:35 PM
Windows 7 64-bit and Pro Tools HD and Avid Mojo milosziv Pro Tools TDM Systems (Win) 1 11-14-2010 11:45 AM
Pro Tools 8.0.4 Freezing (hard lock) during Playback in Windows 7 x64 Jennerstein 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-19-2010 01:37 PM
Avid Windows to Pro Tools/AV Mac eldog Post - Surround - Video 5 06-28-2002 04:39 PM
