Alesis SR16 control of PTLE6 Step-by-step Needed
I have tried forever to get my SR16 to Syncronize PTLE6 to no avail. Every time I connect the SR16 and try anything, It locks up with wierd characters, memory gets wiped out, and It must be reset. I want The SR16 to set the tempo and meter (sync PTLE) in PTLE. Can anyone help me? I have tried a lot of instructions that I just couldn't get figured out. I am looking for any person that could offer a step-by-step.
Thank you so very much. |
Re: Alesis SR16 control of PTLE6 Step-by-step Needed
-MIDI OUT from your Digi (or other) interface to MIDI IN on SR16.
-From Midi Menu in PT, enable Midi beat Clock, set it to send on the channnel the SR16 is set to receive. -PT should now be the master, triggering the Alesis. I may be missing a step or two, I may even be stating the obvious which you've already tried in the past, but oh well, was worth a shot...
www.myspace.com/krou |
Or,,midi out of the sr 16 to midi in of PT make sure the SR-16 is set to transmit MTC,set PT to recieve MTC,,cant remember were,, ,,hit play on you SR-16 and it should all just chug along,,best thing to do at this point is to open a new MIDI track,,have it set to recieve from the SR-16 record arm it and set PT to record,,now it should record any midi that you have programed into the SR-16's sequencer,,it's much better to have the SR-16 follow PT,,rather than have PT follow the SR-16,,it's also easier to have your midi in the same place as your audio incase you need to edit acrros all of your tracks later,,
Quantizing Live drums in 7.4. A Step by Step guide. | Ru_C | Pro Tools TDM Systems (Mac) | 19 | 07-29-2011 07:28 AM |
Step by step procedure for installation on new Mac Book Pro | velectrocity | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-23-2010 12:00 PM |
Needing Step by Step Videos - (read more for details). | Wavelabs | Pro Tools M-Powered (Win) | 2 | 04-16-2009 06:53 AM |
Alesis sr16 midisman setup PTLE6.9 | studiojb | MIDI | 0 | 12-24-2005 11:20 PM |
How to Make an OS 9, Universal installer disc, from a G4, OS 9 CD; Step by Step! | editor | General Discussion | 2 | 04-21-2001 03:55 AM |
