Is it possible to re-load the firmware on DIGI002?
I am running the following: PT LE 6.4 cs9 win XP SP2 I have frequent problems with PT failing to communicate with the DIGI002. Sometimes even when I start the DIGI002 'standalone' with no firewire plugged in it still takes a couple of restarts before it comes up to 'standby'. I am thinking that it would be a good idea to refresh the firmware. Is it possible to do this? Thanks very much for any help. |
Re: Is it possible to re-load the firmware on DIGI
Most likely you are experiencing a problem with a cable harness inside the unit. Please contact tech support by phone to get this taken care of.
650.731.6100 |
Erxp won't load new firmware | RockStarzUSA | Eleven Rack | 0 | 05-10-2011 05:23 AM |
Load Firmware Problem | prone2bme | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-08-2010 03:10 AM |
Digi002 Firmware upgrade ??? | JAMMERMAN | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-13-2004 07:16 PM |
Digi002 Firmware update | jimll | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-18-2003 02:07 PM |
will not let me down load 1.35 firmware.. | Seller | ProControl, Control|24, Command|8 | 4 | 10-14-2002 01:41 PM |
