Old 01-10-2021, 02:01 PM
marsian marsian is offline
Default audio import from video crashes
I found a problem in 2020.12:
When import audio from video, PT renders the file but crashes at the end.
This doesn't happen in 2020.11.
macOS 10.14.6, video container: .mov, video codec: h.264, audio codec: aac
Can someone confirm this issue?
PT HDN 2024.3, OMNI, SYNC HD, Dock, 2xS1, PT Control, MacPro 5,1 12core 48GB, OSX 12.7.4, BM Decklink Extreme 3D
mars13.de
Old 01-10-2021, 07:01 PM
AndrewAction's Avatar
AndrewAction AndrewAction is offline
Default Re: audio import from video crashes
What Encoder or NLE does the export come from? (The latest Avid MC 20.12 has changes and updates to audio exports to .h26x formats that may create a issue)
No Macs here so I cannot test your issue but will follow with interest any confirmation posts here.
FWIW to quickly get working again my workaround for this sort of issue has been to export a stereo broadcast wave file of the timeline from my NLE. Then import that file to Pro Tools independently and use it in a new "reference track"
Andrew
Old 01-11-2021, 02:10 AM
Hi Andrew,
thanks for the reply.
I went back to 2020.11 for the moment.
mars13.de
Old 01-12-2021, 05:39 PM
FYI:
AVID confirmed, that this is a bug in 2020.12.
mars13.de
Old 01-13-2021, 09:02 AM
Cheesehead Cheesehead is offline
Good to know, thanks Marsian.
I'll stick on .11 too until they fix that.
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12
Old 01-14-2021, 06:56 AM
quadraphonics quadraphonics is offline
I had something similar happen when bringing in a series and the video length exceeded the session length. (session set to 6 hours and the videos exceeded 8 hours).
Randall
Randall Smith
Audio Editor/Mixer
Starz Entertainment Group
Denver, CO
Old 01-14-2021, 08:04 AM
reichman's Avatar
reichman reichman is offline
Well that explains why I couldn't rip that reference video off the AVC I got from the MC editor last night!
By the way, PT didn't crash for me, it just got stuck on audio import and I was able to cancel out of the dialog and keep working.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 01-14-2021, 07:46 PM
charleshollins charleshollins is offline
I have the same problem when I try to import audio Cubase crashes... if I load audio from the wire by dragging and dropping, then the download is normal, which gives me the opportunity to work.
Software Programming is all about managing complexity: the complexity of the problem laid upon the complexity of the machine. But in the end, it all comes down to 0 and 1. I write about Software Development on my blogs.
Old 05-07-2021, 11:57 PM
Dr Phil Good Dr Phil Good is offline
The same problem is still present on Pro Tools 2021. I spent hours trying to import video for a dubbing project only to have Pro Tools 2020 crash every time audio and video were imported. The audio and video tracks had different lengths and were unplayable. After upgrading to Pro Tools 2021, the problem changed into something different. Now the video gets imported and it can be played, but the audio import crashes at 80%. The workaround was to import only the video first and later drag in the audio, after exporting it to the hard drive with a third party software (Quicktime, Twisted Wave, etc).
Old 01-27-2022, 02:41 PM
Mixmaster Rick Mixmaster Rick is offline
I'm running into a similar issue as Reichman. I'm running PT Version 21.12.0.97 and trying to Import a Video with attached Audio but it's stuck ~50% of the way.
Id there any fix to this? I've already imported separate Audio files successfully that I want to sync to this Video...
HTML code is On
Import Video - Audio Import Option Disabled sarcanon Pro Tools 12 2 06-14-2016 05:12 PM
PT9 crashes on video import ziphler Pro Tools 9 5 02-10-2011 01:51 AM
Pro-Tools Crashes when I Import Video jimi_d2006 Pro Tools M-Powered (Win) 2 05-10-2010 01:53 PM
Pro Tools crashes when I try to import video acrylonjerey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-11-2009 02:52 PM
Import audio crashes?? tandem Tips & Tricks 1 02-14-2003 05:16 AM
