Old 06-10-2009, 07:31 AM
mdo9 mdo9 is offline
Default Transfuser and Boom
Is there a way to easily import a Boom beat into Transfuser so I can MARIOrise it?
Thx
macpro 8core 3ghz, 10gb ram, osx 10.5.6
mbox 2 pro, ptle8, mcdsp, spectrasonics, reason 4
glyph 050q 250gb & 500gb
godin multiac nylon acs & axon ax50 midicontroller
adam a7's & sub8
Old 06-10-2009, 08:04 AM
jmitchell1532 jmitchell1532 is offline
Default Re: Transfuser and Boom
If you are going for the "8-bit_ nintendo kind of sound, Reason has a few kits that you can load into Re-drum, if you have it.
Jon
HP Pavilion P6000, AMD Athlon II X2 240 (2.8GHz), FOXCONN 2AB1 MoBo, 16GB DDR3, NVIDIA GeForce 8400GS, Two WD Caviar Black Internal500 gig, One WD External 300 Gig, Windows 7 Ultimate 64-Bit, SD2, Metal Foundry, Focusrite Saffire 6, PT 9.03 (stable), Gibson Les Paul Studio (Drop D), Fender Tele (nashville tuning), hand built Carvin Bolt (finished!)
Old 06-10-2009, 08:31 AM
thanks man but i'm actually tryin to stay out of reason these days. unfortunately with trillian being pushed back i guess i'll have to use it for the time being...
adam a7's & sub8
Old 06-10-2009, 08:47 AM
audiogeekzine audiogeekzine is offline
I think on the AIR Users blog there was something about converting BOOM beats to MIDI. That would work I think. I've never tried dragging a MIDI region into Transfuser.
Otherwise, just record 1 bar of the output of Boom. Drag that into Transfuser and chop and screw it that way.
MARIO is the intelligent pattern randomizing function in Transfuser.
@theaudiogeek
| www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com |
Old 06-10-2009, 08:54 AM
Ah ha! I now see the light. Thanks.
Jon
Old 06-10-2009, 08:59 AM
Thanks, do you just record an audio track then drag and drop into transfuser (sorry at work at the moment can't test).
And, yes jmitchell, i was referring to the MARIO function in Transfuser... not necessarily programming nintendo style beats
adam a7's & sub8
Old 06-10-2009, 09:02 AM
yes
@theaudiogeek
Boom needs file Boom.big to run? jonsimoneau Virtual Instruments 4 01-01-2012 03:40 PM
Boom! Noobish Virtual Instruments 7 04-13-2011 01:09 AM
Boom! johnpaulgeorgeringo Pro Tools TDM Systems (Mac) 4 02-11-2011 01:15 PM
Problem with Transfuser and Boom drrogo Virtual Instruments 4 08-29-2009 11:45 AM
installing Transfuser full on Transfuser trial wfasano Virtual Instruments 2 06-30-2009 03:14 AM
