Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 05-09-2021, 11:02 AM
jztrumbo jztrumbo is offline
Default Meter and metronome discrepancy
Hi everyone,
I'm running into a problem trying to write in 5/8, where the metronome is at 77 to the whole note.
When I put the meter in 4/4 the click correctly beats 77 to the whole, but as soon as I adjust the meter the click no longer beats correctly. I'm extremely confused, because the click shouldn't vary at all when beating whole notes regardless of meter change, no?
What am I doing wrong here?
Old 05-09-2021, 02:12 PM
BScout BScout is offline
Default Re: Meter and metronome discrepancy
No. 5/8 is eighth note beat.
There is no "whole note" in 5/8. There are ties though.
Further explanation to make this clear: a whole note (no matter what meter) is 8 eighth notes. A 5/8 bar is composed of 5 eighth notes. To have a "whole note" click starting from bar 1, beat 1, the click would go
bar 1 beat 1
bar 2 beat 4
bar 4 beat 2
bar 5 beat 5
bar 7 beat 3
bar 9 beat 1 (at which point this pattern would repeat)
Which is why this isn't a thing with odd meters.
Old 05-10-2021, 08:14 AM
Thank you! I had considered that, but for some reason didn't it put it together and just assumed Pro Tools was going to treat it as 77 downbeats per minute.
I've rectified the issue by setting a new tempo at whole note=(77 x 0.625), so should be good to go! Much appreciated!
clock discrepancy? drasmith Pro Tools 2019 4 02-11-2020 01:35 PM
Why this discrepancy on the screen? cmbourget Pro Tools 12 2 10-09-2016 10:48 AM
LTC chase and 9 pin discrepancy nobby Pro Tools TDM Systems (Mac) 6 09-25-2009 05:29 PM
Pan law discrepancy between TDM and LE el Daniel Tips & Tricks 6 05-31-2007 03:41 PM
Peak meter discrepancy: ADAT bridge vs. digital mixer Philthy Pro Tools TDM Systems (Mac) 3 11-17-2002 09:07 AM
