Old 02-06-2021, 09:08 AM
devinemke's Avatar
devinemke devinemke is offline
Default Waves V12: WLM Loudness Meter
i recently upgraded from Waves version 11 -> 12. i have noticed that when using the WLM plugin via AudioSuite in Pro Tools, the WLM GUI no longer shows the loudness value during and then after the scan (after AudioSuite render). the only way to see the final loudness value is to examine the CSV log file that WLM pushes out after the scan. this is definitely a change from previous versions of WLM, where you would see the loudness value during and after the scan in the WLM GUI. i have tested this using both stereo and 5.1 audio media (see attached screenshot).
i have 2 machines, both running PT 2020.12:
Mac Pro 2013: macOS 10.14.6
MacBook Pro 2016: macOS 10.15.7
i am only seeing this behavior on the macOS 10.14.6 machine. i have tried completely uninstalling/reinstalling the latest version of Waves V12, but the problem persists.
can anyone running Waves V12 on macOS 10.14.6 corroborate this issue?
thanks
Devin Emke
Audio Post Production
Saturday Night Live, NBC
Old 02-06-2021, 03:26 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: Waves V12: WLM Loudness Meter
Good question for Waves.
Can’t you still use V11 installes? (Legacy)
While this gets fixed.
I haven’t the need to WUP-all so I mostly remain at v11.
t
Old 02-06-2021, 03:33 PM
devinemke's Avatar
i have an open support case with Waves about this. just wanted to get some corroborative evidence here if possible.
Can’t you still use V11 installes? (Legacy) While this gets fixed.
i did a complete un-install of V10/V11/V12 then re-install of V12. would rather not roll back unless absolutely necessary.
thanks
Devin Emke
Old 02-14-2021, 12:26 AM
thanks
It seems that Waves is having a look at all their GUIs now, since they're not scaling up as well as they should. It could be that the WLM UI issue might get addressed when they update it's graphics. Maybe.
Old 05-11-2021, 07:47 PM
dez811 dez811 is offline
thanks
Ive noticed this also, I'm running 10.15.7 though. never contacted waves just started using a different meter.
Old 05-12-2021, 10:36 AM
devinemke's Avatar
i am now seeing this same behavior with Waves WLM on multiple machines running macOS 10.14.x, 10.15.x, and 11.x.
as discussed earlier in this thread, i have an open support case with Waves on this issue. they have now acknowledged that this known bug with WLM version 12 and is slated to be fixed in a future update.
hope this helps. thanks.
Devin Emke
Old 07-19-2021, 07:35 PM
Benny Mouthon's Avatar
Benny Mouthon Benny Mouthon is offline
Seeing the same here, PT 2021.6, Waves 12.7.0.209, can't render a value on a file that's already made, I have to bounce it and measure at the same time.
Old 07-20-2021, 07:00 AM
devinemke's Avatar
Zuurk, the faster workaround is to save the WLM output to a CSV log by clicking "Export CSV" on the bottom right of the WLM GUI and choose "Select Off-Line CSV File".
do this before your scan, then run the scan, then close the plug-in window (very important, or else the CSV will not save), then open the CSV. the last value all of the way at the bottom of the log is your final loudness value. see attached screenshot.
hope this helps.
File Type: jpg Screen Shot 2021-07-20 at 9.53.21 AM.jpg (52.3 KB, 0 views)
Devin Emke
Old 07-25-2021, 07:03 AM
Well that's some good news. It's the sound of "future update" that sounds a little unnerving.
At least Devinemke's Export CSV workaround can help us to get by until then.
Old 07-25-2021, 09:54 AM
Some years ago I upgraded from WavesHell to WavesLess and things work better than ever
HTML code is On
Waves WLM Plus Loudness Meter $29. Yay or nay? moshuajusic AAX Plug-ins 9 12-20-2017 04:08 PM
Waves WLM Plus Loudness Meter brough24 Buy & Sell 2 02-17-2016 10:53 AM
New Waves WLM Plus Loudness Meter nst7 Post - Surround - Video 28 01-18-2014 02:34 AM
Waves WLM Loudness Meter - what do you use? dream5695 Pro Tools 9 22 07-21-2012 08:45 AM
New Waves Loudness Meter for Post nst7 Post - Surround - Video 27 01-17-2012 06:49 PM
