Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 05-07-2021, 12:23 AM
darkwavo darkwavo is offline
Default Re: Carbon with 500 rack- bypassing the preamps / connectivity
Originally Posted by Kyle Splittgerber View Post
Sure thing. Bypassing line input gain improves performance. See highlighted numbers in the attached.
Great!
Makes sense to hook it up to the DB25 and have all options at hand.
Nice design feature too (true bypass) for line inputs.
Cheers.
Old 05-07-2021, 11:58 PM
chrisdee's Avatar
chrisdee chrisdee is offline
Yes, it can function that way (just like with any interface in Pro Tools).
So if am recording my vocal chain (mic-> pre -> comp) connected to one of the Carbon line inputs (for example line input 1) i can also route that signal to one of the outputs and send this to my external headphone amp?
Also wonder if my Omni has true bypass on the line inputs?
Old 05-09-2021, 02:42 PM
K Roche's Avatar
K Roche K Roche is offline
Originally Posted by darkwavo View Post
Great!
Cheers.
Yes I run two outboard FX units one Reverb and one Compressor and they are connected via the DB 25 connections and bypass the gain on the line inputs .That way for example the gain on the comp is controlled completely by the gain knob on the front panel of the compressor.
Another nice feature is that combi XLR-1/4" connectors automatically override the DB 25s so for example you could have an analog Comp, Reverb and EQ connected to the DB 25's (on say channels 3-8 ) But If you plugged in 4 mics into the Combi connectors on channels 1-4 they would automatically override the number 3 and 4 channels on the DB 25's, so you would not have to physically disconnect anything on the DB's
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 05-10-2021, 11:31 PM
Interesting . Super cool feature!
Old 05-11-2021, 04:51 AM
chrisdee's Avatar
What about MTRX Studio. Does it have true bypass on line inputs?
  #16
Old 06-11-2022, 09:30 PM
scremedy scremedy is offline
Great, thank you Kyle.
What is the advantage of bypassing the gain on the line inputs ?
It that a cleaner line in to the converter section ?
And good news on the I/O delay compensation. I use the outs and ins all the time typically to create hardware efx sends/returns , parallel process , etc.
Thanks again !
Hi Kyle - I love the Carbon, it's an beautiful and intuitive piece of tech. I'm looking at 500series to add to the carbon. I see that 500 series chassis come in DB25 and ADAT I/O flavors. All things considered, is there any advantage for either?
Thanks
Scott Compton / Berkeley
  #17
Old 06-12-2022, 06:03 AM
K Roche's Avatar
Thanks
Basically the advantage to ADAT is they are in addition to the 8 channels on the Carbon itself . So either 8 or 16 additional channels (depending on the sample rate you use) so if you need more than 8 simultaneous inputs ADAT would be the way to go.
The DB 25 allows you to have up to 8 additional analog connections = 8 on the DB25 and the 8 physical inputs on the carbon BUT you can only use any combination of 8 total at one time (as there are only 8 converters in the Carbon).... So what I typically do is use 3 Carbon mic pre inputs, and 4 DB25 I/O's for external Hardware FX
System :
Enjoy the Journey
.... Kev...
  #18
Old 06-12-2022, 07:31 AM
XJENSEN XJENSEN is offline
It all really comes down to the conversion quality of the particular ADAT converter at the 500 chassis side.
  #19
Old 06-12-2022, 08:08 AM
Thanks XJensen, agree that is very true.
  #20
Old 06-12-2022, 08:09 AM
Thank you Kev for that scenario. Very helpful.
Scott
Bypassing the preamps stainless ICON & C|24 9 05-26-2007 05:19 AM
Bypassing mbox preamps Denes Pagan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-19-2007 09:55 AM
Bypassing mbox preamps Denes Pagan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-19-2007 07:52 AM
bypassing preamps on mbox Rod Elledge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-30-2004 07:59 PM
bypassing 001 preamps djc8902 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 01-20-2004 08:24 PM
