Sending direct outs to studio room
Hello. I know there are some people here sending multi-track audio to a studio location, and I am trying to look into this. What is the easiest way to do this? Can I install an A-net card at FOH and run cat-5 to my studio? Can the digi send to two different sets of a-net cards? Can I send the same input to both sets? I would love to stay digital all the way into a DAW. Do you know of an interface with which I could do this? I want to send as many channels as possible, but I can do some stemming if necessary. Thanks for any advice.
Re: Sending direct outs to studio room
Probably the easiest way is using the new Madi interface card (up to 64 channels). If you have a computer that is fitted with say an RME madi card you could go straight in, you then have to decide what software you want to use to record with. Obviously if you want to use pro tools you can use the TDM outs (but they are limited by distance,)or you can use Madi, but you need something like the SSL madi to pro tools convertor box. Madi supports up to 2km via light pipe and around 100m using 75ohm coax. Hope this helps.
Roland |
[Emulated] MIDI outs are not sending data | rygundo | MIDI | 1 | 02-10-2010 08:16 PM |
Question about 888-16 AES outs sending 24 bit audio to DA16X | schizo | Pro Tools TDM Systems (Mac) | 3 | 05-31-2007 06:37 PM |
Talkback Dim and Control Room Outs? | Iain Graham | ICON & C|24 | 4 | 03-24-2006 12:17 PM |
splitter box or direct outs? | Eliane Delage | ICON & C|24 | 1 | 07-30-2004 12:53 PM |
14 Direct Outs w/001 + Digimax? | Goody | Tips & Tricks | 0 | 06-20-2001 04:18 AM |
