Old 11-17-2003, 11:23 AM
joeldavidlauver joeldavidlauver is offline
Default working with triggers
hey my friend has some triggers for drums. i was wondering how i would use these with my 002. i've never touched midi for that matter. anyone care to shed some light?
Old 11-17-2003, 12:26 PM
IntelDoc IntelDoc is offline
Default Re: working with triggers
Have not used them myself, but I would imagine it is close to this:
Triggers run into a central brain that enables the sounds. That then is piped into PT via MIDI plug. You would then need to create a MIDI track and assign the input to the appropriate MIDI output that is coming fron that BRAIN. It should then register the MIDI hits when the triggers are hit. I was going to do this setup, but learned that you needed to buy a drum or sound bank that would allow the sounds. There may be other ways, but that is how I understand it works. It will creat individual MIDI hits and the data is stored as MIDI data.
Hope that this is right and that it may help????
-Doc
MONUMENT SOUND
MONUMENT SOUND ON YOUTUBE
Monument Sound Facebook
"Changing how people hear music one track at a time"
Old 11-17-2003, 02:14 PM
Once you have the MIDI events from the triggers in a PT MIDI track, you can use Reason or SampleTank (or other things) to actually produce the sound.
Quad 2.5 G5, 4.5G RAM
Triggers drummer9 The Drum Room 1 09-08-2011 07:55 AM
BFD 2 and RT-10 Triggers arnielarsen Pro Tools TDM Systems (Win) 2 02-18-2011 06:11 PM
Triggers eldusto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-16-2006 11:51 PM
drum triggers?? bluesguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-17-2005 07:37 PM
BFD....Triggers? mosier 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 11-01-2004 05:15 PM
