  #31
Old 10-13-2021, 04:55 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Windows 11 comes out Oct 5th
Originally Posted by EGS View Post
Cool! How does Pro Tools work on Win11? Plugs? Any issues? Thnx.
No issues yet with PT, S1, or Resolve.
I did an in-place upgrade, so everything was still installed. All my plugins were there and the ones I've used so far still work.
Drivers for my audio interfaces were still installed and worked.
Only issue I've had is the Start menu stops responding every once and awhile randomly. In that case I right-click it and choose Search and type in the name of the program I want. And then the Start menu works again
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
  #32
Old 10-13-2021, 05:25 PM
Undead Goat Undead Goat is offline
Pro Tools functionally runs fine on windows 11, any issues I have come from unresolved bugs that got carried over from windows 10. (There are a few) It's pretty much the same windows but with a fresh coat of paint.
  #33
Old 10-13-2021, 10:22 PM
EGS's Avatar
EGS EGS is offline
Originally Posted by Benoni View Post
No issues yet with PT...
Great
Originally Posted by Undead Goat View Post
Pro Tools functionally runs fine on windows 11...
Great
Click for audio/video demo
Click for resume
  #34
Old 10-17-2021, 12:59 AM
nosoul4u nosoul4u is offline
So after doing some further testing this weekend this is what I found.
First to be able to get the Windows 11 upgrade via Windows Update you must be running Windows 10 Build # 2004 64bit or higher and if your system meets all of the minimum hardware requirements after that then it will allow you to do the upgrade no problem.
However, on Friday October 15th Microsoft finally released the Media Creation Tool for Windows 11 so you can be able to create an ISO image or a bootable USB drive for example to do a clean install of it so I decided to give that a try on some of my test equipment that couldn't be upgraded to see if that might work. I will note that none of my test equipment has a CPU that is officially supported but what I found was that as long as the device had the TPM 2.0 module it didn't care about the CPU at all and it would let me install Windows 11 no problem. Then after the clean install completed and it was able to download drivers from Windows Update and whatnot everything seems to be working and Windows Activation also indicates it is running a legit license too.
I haven't had a chance to test Pro Tools on Windows 11 yet but once I do I will report any issues I might find.
  #35
Old 10-17-2021, 06:47 AM
EGS's Avatar
EGS EGS is offline
Originally Posted by nosoul4u View Post
... upgrade via Windows Update you must be running Windows 10 Build # 2004 64bit or higher and if your system meets all of the minimum hardware requirements after that then it will allow you to do the upgrade no problem...
Not in all cases. See post #24 above.
Click for resume
  #36
Old 10-17-2021, 09:08 PM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
I just slapped PT on my new Win11 laptop and loaded up 16 tracks of pink noise with 5 dverbs on each track. Its running without errors at a 128 buffer, which is not bad considering I did zero optimising on the system. The only thing I noticed is the menu names are cut off slightly.
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest
  #37
Old 10-17-2021, 09:50 PM
Sounds about on par with my experience so far. The bugs were also on the windows 10 version. PT runs but according to avid will cut off your file menu if you go above 1080p which, for $400 a year is quite impressive.
  #38
Old 10-18-2021, 12:19 AM
I'm running 1080 on the laptop and it cuts off all of the menus.
Maybe its the 240Hz refresh?
  #39
Old 10-18-2021, 06:36 AM
JoelG's Avatar
JoelG JoelG is offline
Re. text cutoff - are either of you using scaling?
I've seen using scaling cause that effect in other applications.
FWIW, I'm using a 3440x1440 monitor without this issue,
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
  #40
Old 10-18-2021, 12:20 PM
Benoni's Avatar
Joel
Yeah, its usually scaling that causes the issue, not necessarily the resolution.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Pro Tools tabbed windows in MacOs - Windows configuration not working hugocentrique macOS 3 11-06-2023 05:26 AM
Audio glitches with Fast Track Ultra on Windows 10 after updating Windows 10 GregS FireWire & USB Audio Interfaces (Win) 6 12-25-2015 03:40 PM
Windows Guide - Windows 7 Optimizations and Troubleshooting.[349411] cwsand 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 08-12-2010 01:46 PM
Is standalone Windows Audio Drivers v8.0.3 compatible with WINDOWS XP 64 ? VonHelvete 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-28-2010 10:01 AM
Windows server 2003+windows resource manager. odysseys 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-20-2003 10:02 AM
